Very Boring Front Sprocket Spacer Thread
This, I'm afraid, is a rather dull request for a bit of help working out if I've put my spacers together in the right order...
I changed the front sprocket to a 17t a while back and I've had an increasing amount of drive noise from that area since.
I whipped it off today and found the bolt that holds the sprocket in has stretched hugely and I reckon that's the culprit. New one ordered.
My query is that when I pulled the sprocket off, there is a collar behind it. It's not on the Honda parts list as far as I can see. It's sitting out side of the Oil Seal on the Counter Shaft.
I'm wondering if it was a spacer that came with the new sprocket, as it isn't an OEM, or if it's always been there.
I was thinking, if I've put that spacer on the wrong side of the sprocket and the sprockets aren't alined properly then that could be making the noise.
If it is an extra spacer then that might explain the stretch on the bolt that holds the sprocket on, as it won't be all the way in to the shaft and threads will be exposed.
On the off chance, has any one had their front sprocket off recently and noticed if the is a spacer behind it.
Apologies for the deeply boring thread...
(03-06-2017, 04:40 AM)beardyweirdy@me.com_imp Wrote: This, I'm afraid, is a rather dull request for a bit of help working out if I've put my spacers together in the right order...
Don't worry, it's something someone can get their teeth into Big Grin
I've answered my own question, its part of the Countershaft Baring, It's not a collar or spacer.
I'd delete this thread if I could... Admin. feel free to pull if you like.
Glad you found it! It is hard to see on the fiche.
I'll leave it, it may help someone else down the line.
Countershaft baring (sic) bearing?
So where's it supposed to be? Any pics or diagrams? I also changed to a 17T but don't recall what you are posting about, and now I'm concerned.
(03-06-2017, 11:19 AM)736cc_imp Wrote: Countershaft baring (sic) bearing?
Don't be.
It is, as popgun says, not easy to see on the parts diagram. I looked at the gearbox section in the manual and could see that it's part of the Countershaft and bearing that the oil seal sits on. It's wider than the oil seal and it sticks out, airside of the oil seal. The Sprocket buts up to it. It can't be removed.
Now I'm looking for my original OEM Sprocket to measure the width. I could still have an alignment problem.
I'll let you know what I find.
What make is your 17t sprocket?
Replaced the 17t sprocket with a new bolt from Honda.
All noise has now gone and back to normal.
The stretched bolt would appear to be the culprit.
A warning about using a rattle gun to tighten a bolt instead of torquing up with a Torque Wrench I guess.
  Another tire thread: Dunlop TT900GP misterprofessionality 1 363 10-08-2025, 11:57 AM
  Another shock thread, but SHOWA JLEECB 17 1,643 02-09-2025, 11:23 PM
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,032 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,246 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 986 11-20-2023, 01:30 PM
  Front sprocket bolt cant be moved misterprofessionality 55 4,489 03-13-2023, 12:18 PM
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 12,399 12-27-2022, 08:35 AM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,207 11-29-2022, 07:49 AM
   Dutch's High idle thread DutchRutter 17 1,541 09-27-2022, 01:55 AM
Last Post: DutchRutter
  Another Oil Thread dave 11 951 09-15-2022, 09:13 AM
