Spoked wheels, problem
Hi, I've a problem: on about 70 km/h my handlebars flutter. I've seen my rear wheel in not well round, but I've not taken holes or bumps. Total km 3000.
Does anyone has the same problem?
Thank, Marco.
If my calculations are right thats about 45 mph. I assume your flutter is on deceleration with your hands off the bars? If so, this is actually a very common phenomenon, and been going on since I started riding in the mid 60s.. There is no real cure that I am aware of, and I'm not sure of the cause, but type " handlebar wobble between 40 and 50 mph" into google and you will have more to read than you care to. All models, all brands. Some do it more than others.
Secondly..how have you seen your rear wheel is not round?
My reccomendation, check your tire pressures (. 36 F 42 R ) and quit taking your hands off the bars lol.
My CB750 has done this on and off for 20 years. Improper tire pressure and unevenly worn tires seem to be the main causes. So far, I have only experienced it once on the CB1100 and the cause was low tire pressure in the front tire.
Thanks You for answers. The tire pressure is correct. I've seen it standing on central staff on 1°gear on. I can feel better on deceleration as You wrote, but also riding with The hands on the handlebar. I can't believe this could be normal.
superfebo, have a look at the video in [url=http://cb1100forum.com/forum/showthread.php?tid=10122&pid=161411#pid161411]this post. It will give you an idea of what the Ferret was talking about, although, in my experience of the CB1100, your hands would have to be very loose on the bars to feel the wobble. Did you say your rear wheel is NOT perfectly round?
Yes, it looks not perfectly round. I'll try to post a short video.
tire balance issue? wheel weights drop off somewhere?
I wonder whether this post of chync's was meant to be here:
Hi, I can't add the video, you can see it on YouTube
Honda cb 1100 ex rear wheel problem
Here's superfebo's video. Are you sure the wheel is straight?
  CB1100 Idle speed instability problem ericlo69_imp 1,434 115,827 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 1,973 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Chain or sprocket problem ? The Gecko_imp 14 1,184 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 625 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,480 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  CB1100 EX tyres & wheels Ol' RedJ_imp 14 1,085 07-19-2023, 05:04 PM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 625 05-13-2023, 05:43 AM
  Laced wheels ? ashishNJ_imp 3 348 02-08-2023, 01:09 PM
  May have a problem the Ferret 12 828 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,776 10-08-2022, 12:27 PM
