Cold start idle rpm
Does anyone else have a problem with a high idle RPM on a cold start / cold day (< 55 f) ? My 2017 ex starts with a high idle that normalizes once engine heats up. No biggie but was wondering if this is normal.
What do you call high? What RPM?
Is this not normal , like having the choke on with carb. bikes ?
cars do the same when cold , higher idle for short while and than back to normal .
Anytime I start my CB between April and October it immediately has a higher idle for several minutes before it warms up and settles down.
(12-26-2017, 12:36 AM)Lord Popgun_imp Wrote: What do you call high? What RPM?
Between 1500 and 1800, stays high when changing gear and pressing clutch.
(12-26-2017, 01:04 AM)Houtman_imp Wrote: Is this not normal , like having the choke on with carb. bikes ?
It probably is the same thing and is normal.
Mine warms up at about 14000..drops to 12000..then to 1000
If I take off too soon after starting, it will hold the higher rpms for the first mile or so
(12-26-2017, 01:46 AM)The ferret_imp Wrote: Mine warms up at about 14000..drops to 12000..then to 1000
My 14 does this exactly as well
Yeah, thats normal. As the engine warms up the ECU commands the IACV to change the idle air and the idle speed goes down.
FYI, There is no value for cold idle in the service manual that I can find. Only to warm the engine then check for 1100+- 100rpm with a tach that can read at least 50rpm changes.
Thank you all
Ferret, 14000! Then 12000! Man, you sure got a different engine that I did!!! Smile
  CB1100 Idle speed instability problem ericlo69_imp 1,434 118,260 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,134 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Idle a little rough and miss fire when revved johnnyH_imp 3 424 09-15-2024, 12:16 AM
  High engine revs on start up CBX1000_imp 21 1,829 06-06-2024, 02:40 AM
  another idle thread Tom_imp 11 1,008 11-20-2023, 01:30 PM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,706 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,252 09-06-2023, 01:36 AM
  CEL after Jump Start rage91_imp 23 1,592 04-14-2023, 01:25 AM
  High idle mattmcuomo@yahoo.com 7 693 10-29-2022, 11:09 AM
  Fast Idle Problem Solved Nachodaddy 17 1,504 10-08-2022, 09:18 AM
