No power from battery to bike
Ok people here it goes put key in bike turned key every thing came on and then died the needle stop at 3/4 ON THE GLAS CAN ANY HELP ME THANK U VERY MUCH AND GOD BLESS U.
This would be a good example of battery failure, it is certainly the first thing to look at.
If you could take out the compartment under the seat and test the battery before removing it that would be best.
It is not likely to be an electrical fault since the system worked for a short time but still worth checking if the battery cables are not loose.
Do you have access to a battery charger or a way to connect jumper cables?
No need have to start the bike, just check if the battery was the problem.
Let us know how you get on;
Some other things to check if battery checks good.
Set kill switch to off and back on, even a slight brush against this switch may cause a need to reset.
Turn ignition switch on and off several times. The contacts on this switch can get dirty.
Had both these problems occur on my CB.
Ok guys thanks for the help main fuse blew thanks again
Was anybody into the wiring? You never mentioned the main fuse blowing bedore. That would indicate an electrical problem/direct short somewhere. Were the handle bars replaced? Turn signals? Tail light? Fender eliminator put on?
(08-16-2018, 11:10 PM)The ferret_imp Wrote: Was anybody into the wiring? You never mentioned the main fuse blowing bedore. That would indicate an electrical problem/direct short somewhere. Were the handle bars replaced? Turn signals? Tail light? Fender eliminator put on?
I had my fuse blow out of the blue. I found a spare from Honda in the fuse block and swapped it. That one blew also. Once I switched to fuses I picked up at an auto parts store it never blew again. I made sure I used the same amp rating. It left me questioning the quality of the factory fuses.
wow, that's interesting
may not be marked but you have fast and slow blow fuses.
may be right that Honda uses a faster blowing fuse than auto's
us geezers remember household slow blow fuses from the old days right Ferret ;]
(08-17-2018, 12:33 AM)use2b_imp Wrote: may not be marked but you have fast and slow blow fuses.
Just screw the blown fuse out and put a penny coin in the socket and you are good to go! Huh
Or the foil wrapper from a cigarette pack......Ah, I remember those days.... Rolleyes
  ABS , speedometer and battery Walter 10 773 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,475 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 656 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,032 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 272 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,358 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,208 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  GPS power cable The Gecko_imp 10 976 10-06-2023, 12:40 AM
Last Post: suhawk305
  Has anyone installed a power commander in? Doug Shepard_imp 3 481 08-10-2023, 07:20 AM
  Replacement Battery dave 54 3,750 02-04-2023, 12:41 PM
