Tach/Speedo
So... Ive started looking through the threads for info and have seen some of the comments on changing out the speedo and issues to be aware of, specially with the ABS model, but I have not found an aftermarket tach/speedo yet... Any suggestions/experiences/links to previous mentions. I have the 2013 model with ABS... I will keep researching on my end, but I thought I'd learn from the wisdom of the Group.
Why do you want to replace it and exactly which part are you looking to replace?
(11-04-2019, 09:07 AM)chync_imp Wrote: Why do you want to replace it and exactly which part are you looking to replace?
I was hit by a car and the whole unit from ignition to headlight was bent out of shape. Still functional but, difficult to insert key and difficult to read. It is pretty upright now, and slighty angled. I would like to replace the entire speed/tach assembly, housing and all, maybe for something more low profile. I never liked the large dual display. so trying to find options... I do not want to disable ABS and I am trying to keep things as functional as possible.
Someone had a long thread on mods that included an aftermarket speedo/tach combo. As I recall he got it working. I’ll try to find the thread.
Cormanus, this one maybe? http://cb1100forum.com/forum/showthread....#pid239653
That is indeed the one. Thanks, popgun.
It certainly frees up some space for other riding swag.
[url=https://photos.google.com/share/AF1QipN0UqjM7CyFo81FhjQ_-UkJ-3ZeK1IRephnKW0fm9O73SF3ZMN2Mw_VEBZVQArE-A?key=SkZ0T3JjWW85RGN2TGJYTU85XzFhX0dzNGZkOG13]Alternative Instrument Cluster
Thank you for the help! Now, Im going to look for a Speedo replacement... I'll check back in with updates or questions...
  Speedo & Tacho chrome covers Chris Goldson_imp 22 1,677 05-23-2026, 04:43 PM
Last Post: LucienLeFranc
  CB1100 EX fueling & speedo Ol' RedJ_imp 7 608 07-16-2023, 02:17 AM
   Digital tach shorting out kentf1120_imp 1 236 03-16-2023, 09:33 AM
  HELP GAUGE REMOVAL /CUSTOM TACH 911jimmy_imp 96 5,655 07-25-2022, 06:54 AM
  Clock Speedo and Tach died while riding adogsnyder99_imp 2 329 06-15-2022, 01:00 AM
Last Post: 17-CB-002
  CB1100 Meter replaced - Speedo, ODO, not working, ABS light ON HELP! danieljrmurray_imp 14 1,215 03-31-2022, 04:03 AM
  2014 Metric European Speedo peterbaron 25 1,803 07-28-2021, 09:16 PM
  Circuit board behind speedo 1300x4_imp 6 446 02-22-2021, 10:55 PM
Last Post: max
  Speedo/Tacho Gauge alignment? Richard_imp 34 3,282 02-20-2020, 12:29 PM
  Speedo Correction caddy425_imp 7 605 09-25-2018, 02:15 AM
