Yuasa battery date code
After some searching i was unable to find the interpretation of the yuasa date code.
Mine reads; 24041043
Best guess is 24 day/ 04 month / 2010 year batch no 43.
Has anyone got an idea if that is correct?
The number is stamped at the back and opposite the terminals, battery could be original ytz14s.
the bike is listed as 2010 so that could be possible, last time i tested it it still contained 5 Ahrs of capacity, which is about half of the new value, cant work it out, who's got an old battery to compare?
Max , I have an old batterie from my 2014 and the code is 05021443
I am certain that that is the date code , I bought the bike in July 2014 .
Every 4 years I replace the batteries on my bikes with an JAPANESE made OEM Yuasa.
Does this help? https://www.hardwarexpress.co.uk/yuasa-d...s-41-w.asp
It says year month day on your link mi Lord, but it would appear to be maybe Month, day year or day month year in practice according to Houtman's date on his battery ?
May -02-2014 or 05- Feb-2014
I think it must be day , month, year and batch number.
There are no 24 months in a year (Max 's batterie )
Thanks for your help gentlemen, that is precisely what i was looking for.
They must have changed the datestamp order some time ago and that was the reason i could not make sense out of the new way it is used.
Up to a month ago this battery started the bike without hesitation, three days ago i started it for a 10 second quick run and today it was not able to start the engine and i had to jump start the bike with another battery which fired it up again.
After a 10 min ride it started the ( warm ) bike instantly after which i connected the discharger to it and from 12.8 v. down to 12.0 v. it measured 2.6 Ahrs, and would have kept going down until the 5 Ah were discharged but i stopped it and charged it back up.
So on the 24 th of this month it celebrates it's tenth birthday as a functioning battery in the same bikeCelebrate
New price for a replacement is $542 nz and a lithium motobatt equivalent ( mplx9u-hp ) is $250 nz. hmmm...
Thanks for all your help to clear this mystery up for me!
Crikey! That’s an expensive replacement, max. But 10 years is impressive.
(04-13-2020, 04:28 AM)max_imp Wrote: Thanks for your help gentlemen, that is precisely what i was looking for.
Wow! If I got 10 years with the same battery, I'd go with OEM again, but $542 NZ translates currently to $330 US, pretty high. US suggested retail is $188, and they are found online at Honda dealers as low as $144 US.
I also looked on eBay Australia and they have factory activated and charged OEM quality ones for as low as $261 US.
Is it the YTZ14S? They can be had for AU$222 (US$14).
Or maybe $140USD Tongue
  ABS , speedometer and battery Walter 10 816 05-02-2026, 01:29 AM
Last Post: Walter
  Yuasa Battery Life dave 28 2,756 04-01-2026, 04:44 AM
  Rattle on right side exhaust / battery CB1100i_imp 4 706 04-18-2025, 02:48 AM
Last Post: CB1100i_imp
  Battery jumper the Ferret 14 1,188 10-28-2024, 10:58 PM
  CB1100 SA-E 2017 Battery Davidjill_imp 1 297 08-01-2024, 02:33 AM
  wonder battery The Gecko_imp 58 4,908 02-19-2024, 11:20 PM
  Could old/low battery trigger misfire and engine light? Motorsport3_imp 13 1,299 12-17-2023, 08:41 AM
Last Post: Jgarciajr40_imp
  Code 86/ 86-1 Jgarciajr40_imp 6 568 09-29-2023, 02:03 PM
Last Post: max
  Replacement Battery dave 54 4,437 02-04-2023, 12:41 PM
  Winter Battery Maintenance Wagonpeddler_imp 27 2,314 10-18-2022, 01:55 AM
