2014 DLX Wheels on 2017 EX
I have been thinking about replacing the spoke wheels on my 2017 CB1100EX with the silver colored cast wheels from the 2014 DLX.
I know the brake rotors will have to be replaced, and the ABS pulser ring, but I'm hoping the 2017 brake calipers will work. I know all the spacers will also have to change, and even the rear sprocket. I think only the front axle is the same part number.
It looks like the 2014 wheel set is still available from Honda. From what I've seen, the Honda Parts House website has the best price.
Has anyone here done this swap?
I have been interested in doing this as well but so many parts have to be changed that it could become very expensive.
Wondering if in some countries the 2017 was sold with mag wheels.
(06-05-2018, 12:06 PM)Houtman_imp Wrote: I have been interested in doing this as well but so many parts have to be changed that it could become very expensive.
Yep, it ain't cheap. But if I can convince myself that it would work without modifying anything I might spring for it.
That's why I'm hoping someone here has done it before.
Use the code eddie12 for 12% off large orders. [Image: b7c8f1c0172e770755b418601ddbda99.png]
(06-05-2018, 12:59 PM)PowerDubs_imp Wrote: Use the code eddie12 for 12% off large orders. [Image: b7c8f1c0172e770755b418601ddbda99.png]
Thumbs Up
Wow, someone going the other way ... swapping out the spokes for mags. There's a few of us who have gone from mags to spokes. I would be delighted to swap my new silver mags for a set of spoked wheels ... but I'm in Australia.
Amongst the many considerations for your project you might have to consider that the mags could have a thicker diameter rear axle than what fits in your swing arm - 25mm vs. 21mm or something like that, I forget.
Hopefully we'll get to read about your project in this forum.
Good luck.
Just sent you a pm.
(06-05-2018, 01:50 PM)Aussieflyer_imp Wrote: Wow, someone going the other way ... swapping out the spokes for mags. There's a few of us who have gone from mags to spokes. I would be delighted to swap my new silver mags for a set of spoked wheels ... but I'm in Australia.
Good luck.
Thanks for that information. The thicker diameter rear axle my be a deal killer for me. It would be pretty easy to fabricate bushings for a smaller axle, but not sure of a practical way to fit a larger one without cutting and welding my swing arm.
This reminds me of the good old days when you bought an aftermarket accessory and had to change many other things on your bike to get it to fit. Lucky for me a biker buddy owned a machine shop back then.
Good luck.
Perhaps consider:
1. Alternate wheel bearings and crush sleeve to match your axle to the hubs, I.e. Bearings with same OD as the '14 bearings but with ID of the '17 bearings and a crush tube to suit, or
2. Sleeving your axle to fit the ID of the wheel bearings in the '14 hub.
Just some thoughts that you could explore with a machine shop.
  Rear axle diameter 2014 vs 2017 ashishNJ_imp 4 546 08-28-2023, 06:07 PM
Last Post: dopaytoplay_imp
  CB1100 EX tyres & wheels Ol' RedJ_imp 14 1,201 07-19-2023, 05:04 PM
  Cast wheels 18 inch on 2017 CB1100EX with Spoke wheels supruet_imp 5 667 05-13-2023, 05:43 AM
  Laced wheels ? ashishNJ_imp 3 386 02-08-2023, 01:09 PM
  How to remove both wheels? RandyBMC_imp 18 1,489 05-10-2022, 11:12 PM
Last Post: Tom_imp
  Replacing Wheels - Manual Instructions Ludicrous jasonsargonautalis_imp 12 1,287 12-11-2021, 08:52 AM
Last Post: jimgl3_imp
  Hit a Massive Pothole - Need New Wheels jasonsargonautalis_imp 18 1,489 12-09-2021, 01:33 AM
Last Post: Raceman_imp
  Tyres again - spoked wheels - pressures Rogerdj_imp 3 362 07-06-2021, 08:24 PM
  Anybody paint their wheels black on a '13? boynton6spd_imp 2 354 06-14-2021, 11:08 PM
Last Post: MrBob_imp
  removing both wheels Tom_imp 20 1,719 05-21-2021, 01:07 AM
