Oil cooler inspection
Just by accident i looked a bit closer at the engine and noticed a strange situation with the oil cooler;
Turned out i made the mistake of using a pressure washer to remove some dirt behind the oil cooler and had accidentally hit the cooler as well, the water pressure was far too much for the thin fins and had closed more than half of the airflow through the oil cooler.
So i had to take the cooler off the bike which was quite simple, emptied the oil out of the cooler and restore all the closed passages one by one ( whole days work ) and restored almost all of the light weight aluminum fins with some good fitting alu strips in various shapes;
Eventually we got all of them straightened out, applied some paint, removed the oil lines as well and gave them a good clean ( only a small amount of oil seeped out of the passages ) and put all of it back where it had been;
So we wont make that mistake again any time soon and all cooling has been restored
Nice work Max. Looks much better.
Professional repair, Max  Thumbs Up
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Very nicely done Max! Professionally done job.
Holder of the CB1100forum Secret Decoder Ring
2012 ST1300
2013 CB1100
I find your lack of RLETs disturbing
Nicely done on the fix. I know I've thought about using a pressure washer to reach difficult areas, but I was always fearful of damaging electrical this or that.
Nice work, Max and a good reminder to use care on those delicate areas.
There's a difference in riding a naked bike and riding a bike naked.
Won't make that mistake again.
2013 Honda CB1100 Standard. Gone, but not forgotten.
Just FYI, you can pick up an inexpensive "fin comb" on Amazon for not too much money. I recommend the plastic versions that are less likely to  mar the paint. Some of the round combs have several fin spacing sizes that will make much shorter work than doing individual fins by hand. Plus they tend to look more uniform when you can comb several fins together. Be wary of doing this too often though as the aluminum will fatigue and eventually break, but the combs do work well after removing the odd bug that hits hard enough to bend a fin.
2017 CB1100 EX | 2024 Africa Twin AS ES DCT
Thanks Whoops, had no idea this existed and w'll go and have a look around.
Thanks very much for the tip!
Max, all of us see that you will get the restoration done and everything will be returned to its original state. No doubt there, and I am glad the Forum rallied behind the effort.
Not so long ago, I purchased an oil cooler protector to help protect it from rocks and road debris. I am not sure if it would help offset the impact of a power washer, but the thread appears below if you want to check it out:
https://cb1100forum.net/forum/showthread.php?tid=36
I admire attention to detail, patience, and commitment. Clearly, you have all three along with my respect. David
2017 Honda CB1100 EX
Whoops, do you mean something like this?
https://www.amazon.com.au/Baxnore-Automo...90&sr=8-15
  Oil cooler lines pitting DBM_imp 6 593 10-19-2021, 09:05 AM
Last Post: DBM_imp
  Pre-Purchase Inspection for used CB1100s paisa_imp 6 484 05-22-2020, 03:57 AM
Last Post: bioman_imp
  10,000 mile inspection, at 8 months of service SportsterDoc 14 1,194 07-07-2018, 06:00 AM
Last Post: TCinNC_imp
  600 mile service inspection SportsterDoc 2 283 11-19-2017, 02:53 AM
Last Post: SportsterDoc
  Oil cooler LongRanger_imp 104 6,986 02-10-2017, 02:12 AM
Last Post: Desert viper_imp
  USB Borescopes Inspection Camera quail_imp 7 502 06-09-2016, 09:58 PM
  OIL COOLER PAINT BLISTERING aussie59_imp 15 1,085 07-23-2015, 09:19 PM
