Lifting the CB1100 and other basic questions
Howdy--new member here. Love the CB1100 and currently own a 1989 Shadow 1100. The Shadow does not have a center stand, but I see in the photos of the CB1100 that both center and side stand are present--great!
Is the CB center stand suitable for most basic maintenance activities or does the bike need to be raised on a jack--to remove the rear wheel for example? My Shadow has lots of low hanging pipes, tubes, etc. that prevent the jack from centering and lifting without a confusing array of blocks and shims.
I do not anticipate any mods other than adding some kind of wind screen and a way to hold stuff. I have saddle bags on the Shadow and like them. I peaked at the photo page in this forum and saw a few screens/fairings but not much in the way of saddle bags. Is this eschewed by my new family of CB riders?
Looking forward to spending time on this forum while I rationalize the purchase of a new/used CB1100.
I removed both of my wheels using the center stand and jack stands under the frame sliders. I put it up on the center stand, put a floor jack under the front of the exhaust, lifted the bike and slid stands under the sliders.
Greg a lot of us use tank bags and tail packs but we also use saddlebags as well. The problem with saddlebags is rear turn signal location, and using saddlebags may preclude a passenger from using the rear pegs. An excellent place to look at bags in Cinti is Sporttour, an acc shop in Sharonville/Forest Park.
[url=http://smg.photobucket.com/user/theferret111/media/Oct29rides108_zps1efeb4bd.jpg.html][Image: e9f2822531420ac58818ac33ff208296.jpg]
[url=http://smg.photobucket.com/user/theferret111/media/Mensfalltrip2014014_zps3e955d51.jpg.html][Image: e157f25048c32c3694ea290e4913a02f.jpg]
You can do most everything on the centerstand , except you will need to put a padded block or something under the front headers to remove the front wheel.
Oil change is a snap on these bikes.Easily accomplished while on the centerstad.
ferret, just so I'm clear on what you said, are you saying to put the weight of the bike on the headers and lift with a floor jack?
I haven't done it nor have I had a need to remove the front wheel (yet), but that seems like a lot of weight for the headers to support.
I'm always willing to listen to the voices of experience.
That said, I have a paddock stand for lifting the front end, but it's useless if I decide to change the fork springs or install gaiters.
I recently had to take off the front wheel and forks on my CB. I had the bike on the center stand and also used a small scissor jack that came with my Honda Civic. I placed a small board on the jack underneath the center of the bike near the oil drain plug and cranked slowly while checking the stability...Not the ideal way to do it I'm sure but it worked out well.
Rocky..no, I put weight on the back end until tire hits to lift the front off the ground, then slide a block padded with carpet under the headers. Then take weight off the back end. Not much weight on the headers, most is on centerstand and back wheel.
For experiment to see how much weight, put bike on centerstand and you can lift front end off ground with a 4 fingers under the front of the fender. Its pivoting on the centerstand.
(02-12-2015, 12:42 AM)The ferret_imp Wrote: Greg a lot of us use tank bags and tail packs but we also use saddlebags as well. The problem with saddlebags is rear turn signal location, and using saddlebags may preclude a passenger from using the rear pegs. An excellent place to look at bags in Cinti is Sporttour, an acc shop in Sharonville/Forest Park.
I bought my helmet at Sporttour so am familiar with them. I had to relocate the turn signals on my Shadow to install saddle bags, but there is still plenty of room for a passenger. I'm sure I can figure out some way to hold the front end off the ground if service require front wheel removal.
Yea I meant if you used full size bags with the turn signals where they are, your passenger would not have room to get to their foot pegs. Sorry if that was confusing.
(02-12-2015, 04:37 AM)The ferret_imp Wrote: Yea I meant if you used full size bags with the turn signals where they are, your passenger would not have room to get to their foot pegs. Sorry if that was confusing.
Sorry,I described it wrong. In order to install the bags, I had to move the signals. With the bags in place there is room for passenger.
The early Shadows had the turn signals attaching closer toward the front. In later years they were moved to the license plate bracket, where mine are now, allowing plenty of room for saddlebags.
(02-12-2015, 03:00 AM)The ferret_imp Wrote: Rocky..no, I put weight on the back end until tire hits to lift the front off the ground, then slide a block padded with carpet under the headers. Then take weight off the back end. Not much weight on the headers, most is on centerstand and back wheel.
Thanks for that.
  CB1100 Questions from a potential new owner E11even_Hunnit 88 6,886 02-12-2026, 06:02 PM
Last Post: E11even_Hunnit
  Buying 2014 CB1100 and have questions MagnaRider 31 2,820 09-06-2024, 05:24 AM
  Questions... Bazbro_imp 15 1,094 10-07-2020, 12:28 AM
  Beginner questions ceeko_imp 5 442 06-18-2020, 06:54 PM
Last Post: zirconxi_imp
  Basic question, about to purchase 2013 CB1100 non-abs AsHperson_imp 16 1,460 05-29-2019, 04:37 PM
Last Post: AsHperson_imp
  CB1100 - Someone with Basic Skills mike85_imp 40 3,244 05-27-2018, 08:50 AM
  Couple of questions about the spoked wheels on the EX VLJ_imp 14 987 04-02-2018, 05:44 AM
  Hi thinking about getting a cb 1100 have some questions calipo223_imp 54 3,234 03-11-2018, 10:55 PM
Last Post: CB750F_imp
  New owner with a lot of questions.... jdinaz_imp 7 615 10-25-2017, 02:15 PM
Last Post: jdinaz_imp
  '14 CB1100A first ride and some questions Banned_imp 14 856 05-25-2017, 05:22 AM
Last Post: Banned_imp
