Soliciting opinions: Top 5 maintenance items?
In your opinion, what do you consider the most important maintenance items/procedures that you do to ensure the continuing road worthiness and onging performance of our bike? Feel free to list them in order, and feel free to add a 6th, 7th, etc. Thanks in advance for your input.
Oil and filter
Chain adjustment and lubrication
Air filter
Oil and filter
Oil and filter
I'm all about oil changes but Ptero's response below is the correct one!
1. Follow the service intervals and items, and inspection requirements, as laid down in the CB1100 Honda Owners Manual and/or the CB1100 Workshop Manual for your particular model.
2 -5. Follow the ...............
1. Proper tire inflation
2. Change oil and filter on schedule and air filter
3. Proper chain tension and rear wheel alignment (the CB is fussy about chain adj.)
4. Tires when needed
5. Valve check/adj. as scheduled
6. Brake/clutch fluid change as scheduled.
7. Brake pads when needed
Really, these bikes are very reliable. Normally, tire pressure needs to be checked often. Oil changed and chain adjusted and most everything else is scheduled in the book. Keeping it clean will help in the long run.
I'd be interested in what others think.
According to MSF and author David Hough, the pre-ride inspection acronym T-CLOCS should be performed before each ride, and also provides a good overall maintenance priority checklist. Of course, the owner's manual specifies actual service intervals for various specific items.
T--Tires and Wheels. Inspect tread depth, air pressure, check wheels for cracks, dents, listen for wheel bearing issues, make sure brakes are in good order.
C--Controls. Levers, throttle and cables
L--Lights and electrics. Headlight, brake light, running lights, turn signals operational. (Battery well charged, wiring not frayed).
O--Oils and Fluids--Regular oil changes ensure engine longevity. Brake fluid check.
C--Chassis and Chain. Inpect frame for cracks, as bike ages; Lube chain at prescribed intervals.
S--Stands. Side stand and Center stand.
In order of immediate roadworthyness
1. Tire preassure.
2. Chain tension.
3. Leaking/weeping hydraulics.
4. Fork seals.
5. Oil level
These are basically my pre-ride visual inspection every time.
1. A quick walk around the bike for inspection.
2. Tire pressures and wear
3. Chain shouldn't be too tight. Limits swingarm movement.
4. Oil level.
5. Warm it for a minute before heading out for the first time that day.
1. Fuel in the tank
2. Starter working
3. First gear engages
4. Stop worrying
I'm with Pterodactyl, post #3 does it for me but then I am a OEM maintenance schedule sort of bloke.
Regards
Always check the nut behind the handlebars. If that is not in good condition, do not ride!
  Opinions Invited Houtman_imp 25 1,993 08-29-2021, 06:20 AM
  BMW makes a Maintenance Free Chain cbolling_imp 31 2,046 08-31-2020, 06:22 AM
  Is balance shaft adjustment normal maintenance? ohiorider_imp 6 670 09-23-2019, 12:27 AM
  Honest opinions please,part II FLYTYM_imp 16 1,158 08-25-2019, 07:18 AM
Last Post: FLYTYM_imp
  Comments/Opinions on HB C Bow mounts/bags ohiorider_imp 0 200 01-17-2019, 02:19 AM
Last Post: ohiorider_imp
  2014 CB1100 standard & sundry items SportsterDoc 22 1,454 09-11-2018, 10:42 AM
  Maintenance Records... quietguy_imp 33 1,623 09-02-2016, 06:48 AM
Last Post: Riko_imp
  Opinions on "high" mileage bikes Shinchan_imp 21 1,309 05-31-2016, 07:16 AM
  Opinions please on half-cover ecka00_imp 9 546 05-07-2016, 05:55 AM
Last Post: LongRanger_imp
  Opinions - Side panel defect? ecka00_imp 10 566 04-04-2016, 12:22 AM
Last Post: ecka00_imp
