Cb1100 handling (geometry questions)
Ok, now that the bambinos are a little older I'm getting out on the bikes more.. Primarily, more fun stuff so that means the CB Banana
However, I have some questions concerning the stance of the CB.. As far as I can tell the bike is stock in terms of setup (I know a previous owner put low bars and then went back to stock)..
For around town blasting it's great. But I got it into some twisties this weekend.. I notice that in switchbacks i.e. quick transitions from side to side (left to right or vise versa) that the front feels a little loose.. Not bad as it's predictable, but I think it could be better
I know the CB has decent tires, but not sportbike tires for road stick, but I'm fairly certain it's not the case.. I don't remember the shock settings on the rear, I know I have em stiff, but not all the way..
I'm considering putting slightly lower bars, to put a little more weight on the front wheel, and maybe a fork brace just in case it's from some fork flex.. However, before I start tinkering, I'm curious to what other have found for setups..
Thanks in advance
Air pressure? Plays a big role. Front suspension adjusts some. Decent thread on the forum somewhere about setting up the suspension that I found helpful.
Tighten up rear also, less compression. I ride the twisties daily. Bikes not real comfortable on gravel roads but I haven't had much of a complaint in the mountains on some tight roads.
Agree with the above but at the end of the day, it's all relative, right? The CB acquits itself reasonably well in the twisties but it's not a sports bike -- it's not even a sporty bike -- and it's heavy and has budget suspension. So, recognize that it has its limitations. Mine has a fork brace and the bike isn't exactly a scalpel in the twisties.
And here is the suspension setup thread in the How to section: http://cb1100forum.com/forum/showthread....ion+set+up
(04-04-2016, 08:27 AM)Lord Popgun_imp Wrote: And here is the suspension setup thread in the How to section: http://cb1100forum.com/forum/showthread....ion+set+up
Thx missed that, so that's a starting point
A Bridgestone T30 front tire properly inflated and the fork adjusters screwed in will help.
I also changed fork oil to one grade heavier when a fork seal started to leak and had to be replaced.
(04-04-2016, 07:50 AM)LongRanger_imp Wrote: Agree with the above but at the end of the day, it's all relative, right? The CB acquits itself reasonably well in the twisties but it's not a sports bike -- it's not even a sporty bike -- and it's heavy and has budget suspension. So, recognize that it has its limitations. Mine has a fork brace and the bike isn't exactly a scalpel in the twisties.
uh-oh....didn't get the memoHelloHello
Man, I like how the CB stands out in that cookie cutter crowd...kinda like Sean Connery at a hipster bar....Class NEVER goes out of style...
No worries, I didn't either. I enjoy the heck out of mine!
(04-04-2016, 04:57 AM)Hondahawkrider_imp Wrote: Ok, now that the bambinos are a little older I'm getting out on the bikes more.. Primarily, more fun stuff so that means the CB Banana
Thanks in advance
Add some preload on the front, maybe a half turn at a time and see how you like it. I didn't like the stock settings on mine (I described it as "floaty") and ended up with a full turn of extra preload.
  CB1100 Questions from a potential new owner E11even_Hunnit 88 7,079 02-12-2026, 06:02 PM
Last Post: E11even_Hunnit
  Buying 2014 CB1100 and have questions MagnaRider 31 2,975 09-06-2024, 05:24 AM
  Questions... Bazbro_imp 15 1,149 10-07-2020, 12:28 AM
  Beginner questions ceeko_imp 5 464 06-18-2020, 06:54 PM
Last Post: zirconxi_imp
  Couple of questions about the spoked wheels on the EX VLJ_imp 14 1,018 04-02-2018, 05:44 AM
  Hi thinking about getting a cb 1100 have some questions calipo223_imp 54 3,518 03-11-2018, 10:55 PM
Last Post: CB750F_imp
  New owner with a lot of questions.... jdinaz_imp 7 625 10-25-2017, 02:15 PM
Last Post: jdinaz_imp
  What's meant by 'flat handling' and 'lazy front end' ? stormbytes_imp 7 557 07-21-2017, 12:39 PM
Last Post: chync_imp
  '14 CB1100A first ride and some questions Banned_imp 14 878 05-25-2017, 05:22 AM
Last Post: Banned_imp
  Tall riders, exhaust etc. questions (looking for my 2nd bike) justinlself_imp 22 1,518 12-03-2016, 03:25 AM
