2017 Headlight ~ LED type - No great performance thinking of converting
Just my 5 cents on the 2017 LED type headlight.
Last night was the first time I rode my 2017 in the dark, I was disappointed with the "brightness" and "pattern" performance.
I understand that HONDA has to meet DOT specification in regards to luminescence, although the colour of the light is white, it is not bright enough on the black asphalt.
May be I am used to my CBX upgraded H4 LED headlight brightness, this CB1100 LED headlight is just light not bright enough - it is similar to a car day-time running light i.e running e headlight in series therefore 6 volts.
I have 2 questions.
Q1, Can any one confirm whether a 2016 headlight uses an H4 bulb?
Q2 If yes, I want to convert to previous model headlight unit - only keeping my chrome headlight bucket and using the lens and ring.
Thanks
The stock headlight on my 2014 is not fantastic either – but it is the nature of the beast, single headlight old style.
Alain, I'm not sure whether the 2010-16 use H4. The spec in the user manual just says 60/55W. I do know I was surprised to be able to buy a replacement bulb in a country service station so it's obviously a common standard kinda bulb.
BTW, I changed the subject of your post as it was right at the 85 character limit which meant each person responding has to modify it after the forum software adds "RE:"
According to this thread, people have used both an H4 and a 9003 bulb in the CB1100: [url=http://cb1100forum.com/forum/showthread.php?tid=296&page=2]http://cb1100forum.com/forum/showthread....296&page=2
Alain,
Have you tried adjusting the angle? I was very unhappy with the performance of the stock light on my '13. It didn't seem very bright and the pattern was inadequate. I spent 15 min. on a dark road with a wrench and that was a vast improvement. The factory aiming was much to low. Once adjusted upward I got a broader, longer beam that worked much better.
Just a thought.
Thanks, will try by adjusting and get back.
I disassembled the headlight and to my surprise, the LED headlight is a 8 or 10 pin connector.
I can forget about updating it to H4 unless, I have a wiring diagram of the LED headlight circuit on hand.
Also, there is barely any room inside the bowl, there as wires cramped EVERYWHERE inside
Does anyone know if the '17 service manual for the US cover the RS model?
  What the sam he** was honda thinking ? Griz53_imp 31 2,683 01-26-2023, 11:42 AM
Last Post: rboe
  Great News Today ! Houtman_imp 4 490 07-22-2021, 03:32 AM
  lean ABS performance j3gq_imp 2 318 01-02-2021, 11:53 PM
  Looks Great rbike_imp 3 377 10-08-2020, 01:39 AM
Last Post: rbike_imp
  What type of chain with teflon roller seperator zirconxi_imp 3 432 05-14-2020, 02:12 AM
Last Post: max
  Great Deal on a 2017 redbirds_imp 8 664 03-26-2019, 03:18 AM
Last Post: Honda_Fan_imp
  2017 CB1100 EX Headlight omarj_imp 19 1,492 03-19-2019, 09:28 AM
Last Post: DBM_imp
  performance drop - fixed jitaylor_imp 23 1,664 12-09-2018, 11:10 PM
Last Post: jitaylor_imp
  Thinking about buying a cb1100 Ausreed93_imp 19 1,382 11-10-2018, 01:54 AM
  Type of fuel. MrJayGLA_imp 15 1,147 07-19-2018, 01:19 AM
Last Post: SportsterDoc
