Type of fuel.
Hello everyone,
I just bought a new 2017 CB1100EX this week and I cannot see where it says in the manual what octane gas to put in. I am assuming it is at least 89 but should I go all the way up?
G'day MrJayGLA. Welcome.
As far as I know all the CB1100s from 2010-2016 have said they will run on the lowest octane generally available-in the US that's 89, isn't it? In Australia it's 91 RON. According to the user manual, they've also been able to cop up to 10% ethanol.
In the 2010 manual, the information is in the section headed up "MAJOR COMPONENTS". There's a section on fuel and then a page on the use of fuel containing alcohol.
I've pretty much always run the minimum-rated fuel—91 RON in Australia—and can report no ill effects. Call me stingy, but I can;t see the vaule of paying for premium when the bike's built to run on standard.
87 is regular in Nevada (and recommended in owner's manual)
89 is mid grade
91 is premium
In Utah, 85 is available. When I am there I buy mid grade.
85 is regular grade in my area, and it works just fine.
Mr Jay, congrats on your new CB, and welcome!
It would be ideal without 10% ethanol...base on my research and thread somewhere, the Top Tier gas of 91 is mostly ethanol free, but not always.
I use Top Tier gas/91
Well it is in the owners manual, but isn’t it also on one of the stickers on the tank? Or have you already pulled them off like most of us? Smile
(07-16-2018, 10:55 AM)LongRanger_imp Wrote: 85 is regular grade in my area, and it works just fine.
At your altitude, but what if you go to the lowlands?
That can be a problem. I topped off with 85 octane at 6,600 ft. elevation and proceeded to ride back to Phoenix (1,100 ft) on a hot summer day. I immediately noticed the knocking whenever I got hard on the throttle. It was quickly remedied by topping off with 91 octane.
The 85 octane works just fine as long as you stay at high elevations.
I run Wawa ethanol free in both bikes. I think it is 89 octatine.
No issues
Here we use a different scale for octane index, so regular is 95 octane, and premium is 98.
I think the scale here is "RON"
In any case: ethanol content should be between 0% and 10%, and for me the lower the better. Ethanol is corrosive for most rubbers, paint, and I don't think it will do any good in the long term.
  What type of chain with teflon roller seperator zirconxi_imp 3 433 05-14-2020, 02:12 AM
Last Post: max
  2017 Headlight ~ LED type - No great performance thinking of converting 17-CB-002 6 467 07-08-2017, 12:36 AM
  What type of Oil does Honda Recommend? Bighonda14_imp 6 534 07-14-2016, 07:12 AM
  CB1100 Concept Type II RockHop_imp 14 954 03-21-2016, 10:32 PM
Last Post: Capo
  CB1100 "U" lock, One key type. Part number?? Roger the shrubber_imp 7 613 12-06-2015, 07:34 AM
Last Post: Django
  CB1100 are all 50-State Emission Type TINK_imp 6 1,094 07-25-2014, 08:53 PM
