Any forum member personally checked valve clearance?
Or has an owner on the forum changed one or more valve shims? Even if you had a shop perform the check/adjust, what did you find about the clearances at 8000 miles (recommended.)
Any other words of wisdom re this topic?
Bob
I did my first check at 48K miles because the valve cover gasket started leaking and needed to be replaced anyway. Everything was still in spec.
This might help. In the how to section: http://cb1100forum.com/forum/showthread.php?tid=8677
http://cb1100forum.com/forum/showthread....#pid110765
Thanks to all!
Bob
  Valve clearance price Maturecheese_imp 44 3,919 03-05-2024, 07:11 AM
  Whoa- this CB1100 dropped a valve seat- PowerDubs_imp 13 1,296 10-23-2023, 11:43 AM
Last Post: 1973cb750
  About to order the '17 dual bending valve forks for my '14 PowerDubs_imp 60 4,027 09-21-2021, 07:22 AM
  2020 Poll - forum member age Guth_imp 100 8,408 04-22-2021, 01:36 AM
  Tires For Higher Clearance s6p_imp 6 560 04-20-2021, 02:03 AM
Last Post: s6p_imp
  Still lookin for that valve cover..... FLYTYM_imp 0 195 10-28-2020, 07:34 PM
Last Post: FLYTYM_imp
  Valve Extensions rbike_imp 4 440 09-16-2020, 01:48 AM
  Potential new member-is this a good deal? TooManyToys_imp 28 2,001 09-10-2018, 01:50 AM
Last Post: Bheezy27403_imp
  Update on forum member dUh the Ferret 14 889 05-19-2018, 11:37 AM
Last Post: SCCBrider_imp
  Revised valve clearance check interval ohiorider_imp 28 1,915 02-23-2018, 08:38 PM
Last Post: jtopiso_imp
