Valve clearance price
Just been quoted £750 by Thunder road to check the valve clearances during this years service, daylight robbery in my book. I'm old school and remember the eighties when bikes were a damn sight easier to maintain
I will probably sell my 1100RS now and get a Speedtwin as I'm not impressed with the service costs and with the speedtwin I could do that myself.
(02-25-2024, 12:23 AM)m in sc_imp Wrote: why cant you do the 1100 yourself? just get in there.
My first thought upon reading your comment was, "yeah, right, it's a different story on the CB compared to..."
And then I stopped myself because I realized I'm basing this notion that a valve inspection is particularly difficult on the CB1100 because I think I've read others have said so in this forum. But is it?
If a CB1100 valve check is more "difficult" than the procedure for other bikes, then...why? Is it simply more time consuming because there are more steps, for example? Or does one have to be more precise / careful with a certain procedure? Are specialty tools required?
My experience with valve checks: did it 4 or 5 times on my KLR650 always guided by knowledgeable KLR-ists at "tech days" (fun!), involved replacing shims. By the fourth time it seemed somewhat easy. Did it just one time on my RE INT650--valve cover removal for both of these was the hardest part. For the RE, easy to adjust, easy access once you get to them. And just recently on my DR650 which has super easy access to the valves, but the hard part is dealing with angles to hold adjusters in place as you tighten down, better tools next time will help, and I've already ordered a few feeler guages made specifically for the DR which will simplify things.
With service manuel, youtube videos, asking questions on forums, taking pictures, making notes as I went along...they all seemed do-able and I'm no mechanic. For those who have done it, what's different about the valve checks for the CB1100?
Cost to have it done seems to vary. An independent garage I like did the CB inspection for me at 14k miles. No adjustment necessary. The charged about $700, but that included oil/filter change, chain adjustment, brake / clutch fluid flush, new spark plugs and I think a few other things I can't remember.
Valve inspection garage cost is similar for the Honda Africa Twin. It is mostly labour tearing down the bike to gain access to the top end.
Thankfully, many Honda owners found that their clearances were in spec after 40, 50 75K kms and more.
ROFLROFLROFLROFL
It's not so much the inspection which is fairly straight forward, it's the adjustment which is difficult should any valve be out of spec. For one just the valve cover has to come off, for the other the cams have to come out and different size shims inserted to bring it back into spec using special tools.Also on I-4s there is not a lot of space under the back bone frame to work.
Then again, some people have natural mechanical aptitude and are handy at things like that, while others are not. My younger brother has always had a knack with mechanical things and can work on and fix anything, but he can barely draw stick figures and can't properly diagram a sentence. I'm terrible with tools, but am a fairly talented artist and have co-written a book, been published in 7 national and International magazines and was an associate editor for a magazine for a couple of decades (although it was mostly a figure head title as I didn't have to do any actual editing lol).
He had dark hair, dark eyes and is left-handed, I had blond hair, blue eyes and am right-handed (both gray now). We are completely different, but we both love riding motorcycles, and worked in the same motorcycle shop for years. He as a mechanic, and me as a parts/service manager. Different skill sets put to different uses on the same product.
Fun story, Ferret...and now I remember some of the details about what to do if out of spec. At this stage in life, I think I'll continue with what I've done so far: do myself nearly all on my DR650, do what I already can on the CB1100, and not sure yet on the W800. The CB just turned 23k, so I imagine chain and break pads are next up. I might have a go at those. Tires changes...hmmm, pretty easy on the dual sport bikes, tried on my RE INT650, but felt a surge of 4 letter words welling up within me, and colorful phrases I knew not that I knew. I took it into a shop.
(02-25-2024, 12:09 AM)Maturecheese_imp Wrote: Just been quoted £750 by Thunder road to check the valve clearances during this years service, daylight robbery in my book. I'm old school and remember the eighties when bikes were a damn sight easier to maintain
A lot of owners are finding the bike stays well in spec even with big mileage. It might be worth measuring yourself for peace of mind and as long as they are anywhere within spec no need to re-shim.
(02-25-2024, 02:57 AM)pdedse_imp Wrote: Fun story, Ferret...and now I remember some of the details about what to do if out of spec. At this stage in life, I think I'll continue with what I've done so far: do myself nearly all on my DR650, do what I already can on the CB1100, and not sure yet on the W800. The CB just turned 23k, so I imagine chain and break pads are next up. I might have a go at those. Tires changes...hmmm, pretty easy on the dual sport bikes, tried on my RE INT650, but felt a surge of 4 letter words welling up within me, and colorful phrases I knew not that I knew. I took it into a shop.
I got 37,000 out of my original chain & sprockets and have over 37,000 on the replacement set now.
Brake pads however seem to last me about 20,000 miles.
I do what I can to my CB which is oil/filter changes, I've changed the tail light bulb myself, I can adjust the chain ..anything more complicated than that it goes either to my brother or to the head mechanic at my local shop.
BTW if we go out for cheeseburgers, I will order mine no pink with pickle and catsup. Brother will order his med rare and get catsup, mustard, lettuce, pickle, onion, tomato and ask them to throw on some jalapenos. we're just different lol.
Good to know about the pads...cleaned a few months of winter grime off the bike yesterday and noticed the pads getting on the thin side...at 23k miles it might time to look a little closer.
Those onions are gettin' mighty [url=https://youtu.be/6inwzOooXRU]close to you, Ferret.
  Fair Price for a 2017 CB1100EX? Bighonda14_imp 12 1,551 03-08-2024, 04:13 AM
Last Post: deuce17EX
  Good price on 2017 K&H seat PowerDubs_imp 0 234 02-08-2024, 02:05 AM
  Clean 2013 on Ebay for a low price PowerDubs_imp 7 617 02-05-2024, 03:51 AM
  Whoa- this CB1100 dropped a valve seat- PowerDubs_imp 13 1,292 10-23-2023, 11:43 AM
Last Post: 1973cb750
  Good price for 2013 CB1100??? PeteinPA_imp 10 936 09-19-2023, 01:57 AM
Last Post: The Gecko_imp
  Price tag. olafurarason_imp 4 891 09-01-2023, 07:34 AM
  About to order the '17 dual bending valve forks for my '14 PowerDubs_imp 60 3,943 09-21-2021, 07:22 AM
  What's a reasonable price... joecurry_imp 19 1,579 04-23-2021, 12:54 PM
Last Post: Scoot_imp
  Tires For Higher Clearance s6p_imp 6 554 04-20-2021, 02:03 AM
Last Post: s6p_imp
  Price Guidance glenncal1_imp 12 987 11-08-2020, 03:04 AM
Last Post: Guth_imp
