Valve Extensions
Just a heads up if anyone didn't know or experience information to the effect that 100% do not use ANY valve extension on your wheel unless you have a metal valve stem. I had (on my RV) a rubber valve stem "explode" open on the shaft - split horizontally because I had a simple 2" 45 degree extender attached. No need for long story, but my metal valve stem was replaced without my knowledge. As I did some investigating, some on MCs use them. - DON'T unless you upgrade valve stem to metal!
I looked for 90 degree stem extenders in every auto parts store around, and there are plenty of them around here, couldn't find one. Didn't want to get online. I wanted to put it on when I checked air and not leave on permanently. Finally found an extender, but it's a truck tire extender, meant to be mounted and left there. It must be screwed on every time. It's cumbersome, but works.
Thank you for your advise , I do not use extenders as the flexible head on my Milton air inflator is easy to use.
As per Ferret's advice I had Kurveygirl angled stems installed when I had the tires changed.
Yeah, good advice. I work around a lot of trucks and trailers and have seen some tire failures from broken valve stems. I had 90 degree stems put on as well with my recent tire change.
  Valve clearance price Maturecheese_imp 44 3,807 03-05-2024, 07:11 AM
  Whoa- this CB1100 dropped a valve seat- PowerDubs_imp 13 1,292 10-23-2023, 11:43 AM
Last Post: 1973cb750
  About to order the '17 dual bending valve forks for my '14 PowerDubs_imp 60 3,943 09-21-2021, 07:22 AM
  Still lookin for that valve cover..... FLYTYM_imp 0 192 10-28-2020, 07:34 PM
Last Post: FLYTYM_imp
  Revised valve clearance check interval ohiorider_imp 28 1,878 02-23-2018, 08:38 PM
Last Post: jtopiso_imp
  Valve in muffler Garry Richards_imp 9 581 06-07-2015, 12:05 AM
Last Post: Tyke57nz_imp
  valve timing inaccuracy? VTR1000F_imp 55 3,929 12-04-2014, 02:51 AM
Last Post: Guth_imp
