Hello from Florida - may need your help ....
Looking forward to getting help from this group as I just bought a 2014 CB1100 DLX and it has a few issues.  With only 7,000 miles it has a yellow engine light on; the Green N display is always on regardless of gear selected and a red light on the right.  Not sure what that is for - maybe oil?  It also leaking fork gaskets.
I have been working on several 1970s CB750s, but this is my first "modern" bike.  It runs well, just those issues i mentions above.
HondaLou
Attached Files Thumbnail(s)
Welcome to the forum, nice DLX ride!
This could be helpful and very similar, old forum = if accassible = be patient,  post #8 by pekingduck .... and more:
https://cb1100forum.com/forum/showthread...#pid260656
Need the cluster pic when idling.. to addres the issues or DTC's
To check your DTCs
http://cb1100forum.com/forum/showthread....014&page=2
https://www.youtube.com/watch?v=iwSllBQNsWc
https://imgur.com/lsoU2Tk    << this is Max diagram <<
See if you can find somthing here as well:
https://cb1100forum.net/forum/search.php...desc&uid=0
           "Drop a gear and disappear"®
'24 Kawi Z650RS - Hooligan®
            *Grand Chancellor*
Welcome to the forum, HondaLou and congratulations on the DLX. The 'old' forum (http://cb1100forum.com) is not supported and therefore unreliable. If you get an error message, try later as it goes on and off-line. It's also likely the threads peterbaron has referred to transferred to this forum, although pictures may no longer display.
Try search for leaking fork seals. There was once a thread with a simple fix that you can try as a starter.
https://cb1100forum.net/forum/showthread.php?tid=5605
Front fork seals:
https://cb1100forum.net/forum/showthread...+fork+seal
https://www.youtube.com/watch?v=2v8lRdb_ctU
https://cb1100forum.net/forum/showthread.php?tid=4738
https://www.youtube.com/watch?v=mm2F08Ys_zU
https://www.youtube.com/watch?v=0TCYIEcDcts
            *Grand Chancellor*
(03-20-2026, 03:02 PM)peterbaron Wrote: Thank you Peter.  The first 2 links come up as error.  But the Youtube link shows me how to reset oe clear the codes.
To check your DTCs
Peter's first 2 threads can be found on this forum too:
https://cb1100forum.net/forum/showthread.php?tid=4852
https://cb1100forum.net/forum/showthread...36#pid6836
(03-20-2026, 08:54 PM)Cormanus Wrote: Peter's first 2 threads can be found on this forum too:
Thank You - these links work.
Welcome to the Forum. Peterbaron and pekingduck are two of our best and brightest mechanics. I am sure their posts will prove useful. David
2017 Honda CB1100 EX
Hello and welcome HondaLou.  I was away for a while and just got a chance to check my manual. The only red light on the right side I can think of is the oil pressure warning light that is in the tachometer face.  It should be an oil can shape.  When the engine starts, oil pressure will turn the red light off, but don't be alarmed (yet).
The green neutral light is independent of the gear position indicator, so likely the problem is the neutral switch.  Both oil pressure switch and neutral switch are underneath the engine, and both have a single wire - light green for the neutral light and dark blue with a red stripe for oil pressure.
AND both wires are share a 2 pin connector.  As they leave their respective sensors, the 2 separate wires are covered with a black sheathing, and combined into a subharness to the 2-pin connector (black).  This routes along the lower side of the clutch cover, and plug into the main harness under the right side panel.  There are 2 metal wire clamps along the bottom of the clutch cover that may have pinched them.
It is likely that the wires were pinched to ground, which would cause both problems simultaneously.  You can unplug the connector, and neither light should go on.  If you unplug the connector and unplug both sensors, there should be no continuity to ground.  If there is, it's a sure sign the harness is pinched.
(03-25-2026, 10:45 AM)pekingduck Wrote: Hello and welcome HondaLou.  I was away for a while and just got a chance to check my manual. The only red light on the right side I can think of is the oil pressure warning light that is in the tachometer face.  It should be an oil can shape.  When the engine starts, oil pressure will turn the red light off, but don't be alarmed (yet).
Super Helpful PekingDuck!  Im thinking this may fix the N light from always staying on.  The "other" red light that is staying on is right of the N light display.
It looks like a temp logo.  Comes on and stays on as soon as key turned to start.  Maybe related to the DTC code I am getting in the orange display?  DTC blinks 7 times.
See photo below
  Greetings from Florida Jeb 13 1,120 12-21-2025, 06:04 PM
Last Post: suhawk305
