Shorter rear shocks?
ss2wheels_imp Offline
Threads: 40
Has anyone found shorter rear shocks or a lowering block for the rear?I would like to drop the front and the back just about an inch,life is hard somtimes at 5-5.Sad
03-30-2014, 02:00 AM
Randy B Offline
Palm Bay, Florida USA
Threads: 85
Likes Given: 133
RE: Shorter rear shocks?
Be very weary of speed bumps if you do this. I have to avoid them as it is because I will bottom out the CAT on them.
Oh...and you might be better served by getting a stock seat from Japan. They are lower to begin with (short people over there don't ya know) and that would make it easier to sell on later if you so chose.
03-30-2014, 02:04 AM
Threads: 40
(03-30-2014, 02:04 AM)Randy B_imp Wrote: Be very weary of speed bumps if you do this. I have to avoid them as it is because I will bottom out the CAT on them.
Is yours lowered Randy?
03-30-2014, 02:12 AM
Guth_imp Offline
Threads: 125
I would second the idea of looking for a lower seat, or having your seat modified.
03-30-2014, 03:19 AM
Randy B Offline
Threads: 85
Likes Given: 133
Nope...stock height.
davidsargee_imp Offline
Threads: 6
Speed bumps on my street, Dodgy, hate'em. I haven't bottomed on them, but must be very careful.
+1 on Japanese seat, or modify the stock seat. .
03-30-2014, 03:35 AM
redbirds_imp Offline
Threads: 186
I would recommend a lower seat also. I'm vertically challenged also at 5'6". I had the seat of my ST1300 customized and made lower a few years ago and it worked out well. Sargent in Jacksonville, FL and Spencer, also in FL do great seat mods at a modest cost.
http://greatdaytoride.com/Home_Page.php
http://www.sargentcycle.com/
03-30-2014, 03:54 AM
Aussieflyer Offline
Threads: 17
Likes Received: 5 in 1 posts
I'd be happy to swap my standard seat with a taller seat - I'll put up a post in the FS section. The Aussie bikes came out with the low Japanese seat and as I am 6'1" it is not so good for me. BTW my seat is as new ... spends 99% of the time on the shelf as my bike has a single seat.
03-30-2014, 11:32 AM
flynrider Offline
Phoenix, AZ
Threads: 28
Likes Received: 6 in 2 posts
So, it's not just me. I noticed that my CAT scrapes if I ride out of my driveway onto the street at an angle (and it's a fairly gentle slope). Last week I came up on a speed bump in a parking lot and made sure to go nice and slow but still ended up with a light scrape.
This is my first bike with a big CAT sitting under it and the first bike that I had to worry about bottoming out under relatively normal riding conditions.
I +1 Randy's suggesting to lower the seat instead. You can buy a lower seat, or have a local upholstery shop shave some foam off of your original and recover.
03-30-2014, 12:19 PM
Pertegaz_imp Offline
Threads: 2
In my case I lowered the front fork brackets about half inch and set the rear shocks to the softer set up, and my CAT scraped some times... shorter rear shocks will be a nightmare...
03-31-2014, 06:14 AM
  Nitro Piggy Back Shocks touchetteweb_imp 3 410 03-29-2022, 12:39 AM
  Hagon Shocks: Response to Inquiry Huladog_imp 10 1,100 12-20-2021, 06:32 AM
Last Post: LikeAfox_imp
  New YSS shocks,Hyperpro Progressive front springs,gators ozigoo 10 983 10-03-2021, 04:03 AM
  A question about shorter cables,brake lines. FLYTYM_imp 3 463 03-30-2021, 01:41 AM
Last Post: sonnyb_imp
  ZRX Shocks( Probably Revisited) Rox_imp 3 409 10-30-2020, 12:16 PM
Last Post: IndianRider_imp
  Amazon rear shocks DBM_imp 11 846 03-10-2019, 01:26 PM
Last Post: qmaven_imp
   Any suggestions on shorter aftermarket shock? FLYTYM_imp 7 791 01-30-2019, 06:02 PM
Last Post: Desert viper_imp
  Ohlins shocks for 2017 Houtman_imp 27 1,880 11-29-2018, 02:50 AM
Last Post: nhawk7504_imp
  Ohlin Shocks for 2017 Houtman_imp 4 454 09-02-2018, 03:02 AM
  Gears Racing Shocks camoto_imp 16 1,452 12-03-2017, 12:16 AM
Last Post: camoto_imp
