License plate holder
RetroSeattle_imp Offline
Threads: 17
Inspired by the Chip Beck thread, I came up with a simpler solution. Went to the hardware store and bought a 4" by 10" sheet of thin (1/16th inch) aluminum plate for craft projects. I cut it down to 4" by 7" to match the license plate and used my grinding wheel to put a radius in the corners. Then drilled four holes to match the plate, and two holes to match the heavy stock license plate holder. Since you can't countersink such thin sheet I got four nylon spacers to go in-between the license plate and my new holder plate. Added two reflector buttons to keep the WA state patrol happy.
Here's what the plate looks like when installed.
And a side view showing the little nylon spacers between the license plate and the holder.
04-22-2014, 10:12 AM
CB4ME_imp Offline
Threads: 183
RE: License plate holder
Retro - that's really nice work. It sure improves the look. Well done!
04-23-2014, 10:55 PM
dailyrider_imp Offline
Threads: 16
Thanks. I am going to do this. I don't care for the bracket I made.
04-24-2014, 11:11 AM
TINK_imp Offline
Threads: 36
That's what I'm talking about. Great job.
04-24-2014, 04:21 PM
redbirds_imp Offline
Threads: 186
(04-22-2014, 10:12 AM)RetroSeattle_imp Wrote: Inspired by the Chip Beck thread, I came up with a simpler solution. Went to the hardware store and bought a 4" by 10" sheet of thin (1/16th inch) aluminum plate for craft projects. I cut it down to 4" by 7" to match the license plate and used my grinding wheel to put a radius in the corners. Then drilled four holes to match the plate, and two holes to match the heavy stock license plate holder. Since you can't countersink such thin sheet I got four nylon spacers to go in-between the license plate and my new holder plate. Added two reflector buttons to keep the WA state patrol happy.
Very nice looking job. I'm going to try that.
Do you have to have the reflector buttons by law in Washington?
04-24-2014, 10:01 PM
Deanohh_imp Offline
Threads: 5
A 4x7 piece of .125 black abs from Tap Plastics was strong, flat, easy to drill and grind, and thick enough to countersink for 2 6mm flathead screws.
04-24-2014, 11:18 PM
rboe Offline
Phoenix, AZ
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
I did something very similar for the Griso (except for the black frame bit) while waiting for my stock holder part to arrive from Moto Guzzi. Worked like a champ. I did not use the washers and it seemed to look just fine anyway.
04-24-2014, 11:54 PM
Threads: 17
I'm told that in theory you do. I think the stock reflectors look really clunky so used the buttons instead. I removed all of the reflectors pointing to the side as well, but I think those are only needed so Honda can get DOT approval in the US.
04-27-2014, 11:24 AM
Red Mist_imp Offline
Threads: 12
Keep an eye on that thing. Aluminum will not stand up to the vibration. Looks very nice though. Have it duplicated in steel for longevity.
04-28-2014, 10:36 AM
GUNFTR_imp Offline
Threads: 4
try simply drilling two holes in the plate and mounting directly. Simple, quick and fast.
05-02-2014, 11:16 AM
  Helmet holder sticker Frankenstein Garage_imp 13 971 02-28-2025, 08:52 AM
  Advice - carry water bottle and side stand plate? 4 Paws_imp 41 2,663 07-23-2022, 06:02 PM
Last Post: rich_imp
  License Plate/Tail Light Bracket eddi0_imp 0 246 03-08-2021, 09:42 AM
Last Post: eddi0_imp
  Where to get a seat pan/plate? Sodbuster_imp 4 552 10-26-2020, 10:53 PM
Last Post: Sodbuster_imp
  Cannot attach Helmet to the bike helmet holder. 17-CB-002 7 577 07-02-2020, 01:52 AM
  Honda "Power of Dreams" License plate frames pekingduck 15 1,242 06-01-2020, 11:24 AM
Last Post: TXBikerGuy
  Getting rid of the ugly license plate bracket. ChipBeck_imp 93 6,345 05-21-2020, 02:02 AM
  Side mount plate number CB1100RS Moe_rider_imp 0 291 11-03-2019, 07:54 PM
Last Post: Moe_rider_imp
  Handlebar holder suggestions? astyles_imp 1 282 08-10-2018, 02:49 AM
Last Post: tnelson99_imp
  Skid plate justinlself_imp 10 736 12-01-2016, 12:16 AM
Last Post: Ulvetanna_imp
