Greg, here's the Yoshi Badge
CIP57_imp Offline
Threads: 68
Just received them from Thailand, took a month
If you buy them roll the badge with your finger on a piece of PVC to get a bit of a curve, that's #2 on there, the first one i could not get to seal properly.
[url=http://s1034.photobucket.com/user/cipolla57/media/photo_zpsff37850c.jpg.html][Image: 3bc94e5477e1d56115610a85b58c266c.jpg]
06-26-2014, 05:06 AM
Ridem32_imp Offline
Threads: 51
Looks good! Those valve stem caps look pretty good also.
06-26-2014, 05:36 AM
CIP57_imp Offline
Threads: 68
RE: Greg, here's the Yoshi Badge
(06-26-2014, 05:36 AM)Ridem32_imp Wrote: Looks good! Those valve stem caps look pretty good also.
Thumbs Up
06-26-2014, 05:47 AM
Greg_imp Offline
Threads: 8
Are they plastic? Metal? Looks good. I'll PM you for the cost details.
I'm still nervous about taking off the factory badge. I have the hand-bent pipes which are slightly more matte than yours. The badge appears to be aluminum and it's fastened on there good; must be heat resistant adhesive too?
06-26-2014, 10:03 AM
CIP57_imp Offline
Threads: 68
(06-26-2014, 10:03 AM)Greg_imp Wrote: Are they plastic? Metal? Looks good. I'll PM you for the cost details.
The badge comes off clean than use rubbing alcohol to clean any residue.
There the same material as the larger badge. I order 1 than 3 more. I received the package of three today. They have plastic protective film on the outside, don't forget to peel it off. As long as you roll it a bit to get a similar contour of the pipe before install your fine. There only a couple dollars no worries, I'll PM you for your address.
06-26-2014, 10:30 AM
  Poking holes in a yoshi 3rdcoastcb1100_imp 6 560 06-24-2020, 05:19 PM
Last Post: treedoc_imp
  anybody have a carbon yoshi gtmn_imp 0 242 04-02-2017, 10:40 AM
Last Post: gtmn_imp
  Yoshi system - oil filter removal Razor 7 571 07-19-2015, 10:34 PM
Last Post: Razor
  Yoshi rscv Arctic cb1100_imp 4 411 05-03-2015, 03:05 PM
Last Post: Arctic cb1100_imp
  Yoshi install help chrisross_imp 4 383 06-28-2014, 07:56 PM
Last Post: Dengie Boy_imp
  Yoshi vs Stock CIP57_imp 12 886 05-17-2014, 05:39 PM
Last Post: CDN_RIDER_imp
