Touring screen for road comet
Lambotte_imp Offline
Threads: 2
So I've come to my senses and have decided to keep this wonderful bike. I cannot make the national cycle shield work. The noise is simply horrendous. I do have the road comet and have given thought to buying the touring screen. Does anyone have first person experience with this? How's the protection, noise and turbulence? Samurider sells it separately so I have a source.
Thanks.
Kevin
Honda CB1100A
Honda CTX700NDCT
08-04-2014, 01:15 PM
Likes Given: 1,012
RE: Touring screen for road comet
Glad you've decided to keep the bike. Thumbs Up
08-04-2014, 03:23 PM
vfrpaul98_imp Offline
Threads: 15
(08-04-2014, 01:15 PM)Lambotte_imp Wrote: So I've come to my senses and have decided to keep this wonderful bike. I cannot make the national cycle shield work. The noise is simply horrendous. I do have the road comet and have given thought to buying the touring screen. Does anyone have first person experience with this? How's the protection, noise and turbulence? Samurider sells it separately so I have a source.
Thanks.
Kevin
Honda CB1100A
Honda CTX700NDCT
SEARCH road comet fairing, by vfrpaul98, its on page 1
08-04-2014, 09:02 PM
Huladog_imp Offline
Threads: 23
I'm running the touring screen, seems to work better than the standard low screen but you will have more shaking of the entire fairing. I solved that by adding some small hard neoprene pads to the top edges of the instruments to fill the gap with the edge of the fairing body. Another member on the forum suggested that solution and it's simple and works.
I seemed to have picked up a buzz in the fairing somehow with the change but that really doesn't make sense since I can notice it at idle as well as at speed, maybe the change in the weight of the screens makes the fairing buzz.
Overall it looks pretty good and works well enough without buffeting but like usual your situation may differ.
Aloha,
Huladog
08-05-2014, 03:25 AM
Threads: 15
(08-05-2014, 03:25 AM)Huladog_imp Wrote: I'm running the touring screen, seems to work better than the standard low screen but you will have more shaking of the entire fairing. I solved that by adding some small hard neoprene pads to the top edges of the instruments to fill the gap with the edge of the fairing body. Another member on the forum suggested that solution and it's simple and works.
Aloha,
Huladog
I took my comet fairing off to remove the headlite and install a Osram 65/70 bulb. after reassembly during my ride a very loud buzz was coming from the headlite/fairing area. inspection revealed harness connectors inside the headlite rattleing against the shell. I removed the shell and lined it with plumbing insulation tape 1/8"thick 2"wide sticky on just one side. no more buzz from the shell or fairing.
Paul
08-05-2014, 06:28 AM
Huladog_imp Offline
Threads: 23
Thanks, Paul! Will go check that out since the buzz tends to bug me.
Aloha,
Huladog
08-06-2014, 06:38 AM
Huladog_imp Offline
Threads: 23
Thanks for Paul, found the irritating buzz in the headlight shell due to the wiring connectors rattling against the plastic headlight shell.
For mine I think it was the red connector laying on the bottom of the shell since it's pretty loose and there were rub marks on the inside of the shell.
Used some thin foam packing sheets to wrap that connector plus the big bundle of connectors and wires running across the top of the headlight shell.
Started it up in the garage and no more buzz!
Mahalo,
Huladog
08-10-2014, 08:35 AM
the Ferret Online
Likes Given: 789
How about that! Good job Paul!
08-10-2014, 10:18 AM
  power port and Samurider Road Comet Fairing 1 tdbru 9 1,016 05-04-2025, 07:20 PM
Last Post: tdbru
  Road Comet Masqeroad: A Beautiful Pragmatic Response rdprdp01 7 1,056 05-04-2025, 11:33 AM
Last Post: rdprdp01
  Road Comet: A Beautiful Pragmatic Response rdprdp01 12 1,073 10-29-2024, 12:25 AM
Last Post: rdprdp01
  Wanted. Chick design comet 2 windshield Nightryder22_imp 15 1,277 01-22-2023, 03:07 AM
  Road Comet Fairing Catbird_imp 47 4,510 08-16-2022, 10:33 PM
  MRA Vario-screen ChiefJP_imp 6 645 05-11-2022, 01:07 PM
   Road comet 2 fitment correct?? gretle_2.0 8 852 05-07-2022, 11:08 PM
  Tall Riders and Comet striped shield Nightryder22_imp 11 1,128 04-08-2022, 09:28 PM
  Road Comet 2 Impressions Frulk_imp 12 943 11-14-2021, 07:09 PM
Last Post: mrded_imp
  road comet fairing vfrpaul98_imp 75 5,338 10-21-2021, 02:41 AM
