Yoshimura Exhaust
JohnLM_imp Offline
Threads: 2
Yoshimura Exhaust
Sorry about another exhaust thread but I've looked all through the site as much as I could and not found very much info on the Yoshi full system . Anyone running one of these ? The Yoshimura tech people said you don't have to use a fuel management system with it . I don't mind if it is somewhat quiet or you don't gain very much power , I like the look of it .Thanks everyone
11-07-2014, 04:33 AM
HikerToo_imp Offline
Threads: 114
RE: Yoshimura Exhaust
Post a link to it....always helpful and keeps each person from having to find what you are talking about.
11-07-2014, 10:30 AM
JohnLM_imp Offline
Threads: 2
Here's a link for that pipe http://www.samurider.com/?p=21433
11-07-2014, 01:41 PM
Rick Froscheiser_imp Offline
Threads: 5
I installed a yoshimura exhaust and did the pair valve mod. It seems to run great. I had a local shop run it on their dyno to check the air fuel ratio and it is running at an average of 13. So I decided not to invest in a programer. I will try and get the graphs and numbers posted this weekend.
11-07-2014, 03:16 PM
JohnLM_imp Offline
Threads: 2
Thanks Rick
11-07-2014, 07:00 PM
Gumby 1100_imp Offline
Threads: 17
(11-07-2014, 03:16 PM)Rick Froscheiser_imp Wrote: I installed a yoshimura exhaust and did the pair valve mod. It seems to run great. I had a local shop run it on their dyno to check the air fuel ratio and it is running at an average of 13. So I decided not to invest in a programer. I will try and get the graphs and numbers posted this weekend.
Rick,
Is there still good access to the oil filter with this system? According to the Yoshimura web site, they only state that the Oil Plug is still accessible and that you can still use the stock Centre Stand. Do any modifications to the centre stand bracket need to be made if you have a 2014 CB1100?
Thanks in advance!
11-07-2014, 09:08 PM
4fout2_imp Offline
Threads: 0
http://translate.google.com/translate?hl...rev=search
11-07-2014, 10:52 PM
Threads: 5
Rick,
Thanks in advance!
Rick,
Thanks in advance!
I have a 2013 so do not know about brackets for the 2014. It looks like I can get the filter off ok. I have not tried yet. Only have about 300 mile on last oil change.
11-08-2014, 12:50 AM
CIP57_imp Offline
Threads: 68
John,
I have a 2013 and there are no issue regarding the oil filter. The stock exhaust does have a stop for the center stand, when you install the Yoshi it does require a bracket to be installed for that stop which is included. You can expect gains without any A/f ratio changes. Here's a sound bite with the pair mod::
[Image: 97635259f8ded0c6bafec5ca2147ee33.mp4]
The 2014 requires a bit of modification to use the stand unless the manufacturer has recently come up with a new design.
[url=http://cb1100forum.com/forum/showthread.php?tid=4020&highlight=yoshi]http://cb1100forum.com/forum/showthread.php?tid=4020&highlight=yoshi
11-08-2014, 01:31 AM
JohnLM_imp Offline
Threads: 2
Thanks CIP57 for the sound bite , that really lets us hear what the Yoshi sounds like . I believe they have sorted out a bracket for the center stand for the 2014 model . It was kind of funny when I talked to the Yoshi tech guy a couple of days ago about the full system he kept bringing up every sentence that the pipe was only to be used on the track . Legally he probably had to say that , but 3 times ?
11-08-2014, 02:05 AM
  Yoshimura RS3 replacement for an '13 Jurlie_imp 7 737 07-28-2024, 01:47 PM
Last Post: Glockrocks83_imp
  Yoshimura RSCV Full Exhaust System Stealth128_imp 43 4,195 11-29-2022, 10:38 AM
Last Post: mrded_imp
  Dart flyscreen and a little Yoshimura stain magic 1985CB450_imp 19 1,897 10-24-2022, 04:12 AM
Last Post: 1985CB450_imp
  Yoshimura RS3 Install. 2013 Kit on a 2014 and sorted the center stand issue! rdtshaw_imp 17 1,398 01-05-2022, 10:54 PM
Last Post: Nibis_imp
  The 2013/2014 Yoshimura Centerstand Bracket Issue Rox_imp 0 264 07-28-2020, 02:40 PM
Last Post: Rox_imp
  Yoshimura ceramic coating longevity Buzzard Biker_imp 10 900 01-21-2020, 10:33 PM
  Yoshimura vs Moriwaki bioman_imp 9 834 12-06-2019, 07:01 AM
  Center stand mod for Yoshimura system Razor 9 803 09-06-2019, 05:20 AM
Last Post: Nemo_imp
  Yoshimura RS3 Exhaust Can install and review Frulk_imp 4 446 11-02-2018, 06:57 AM
  Center Stand Shaft Bolt, Yoshimura RS3 Exhaust HansenCB_imp 8 611 07-28-2018, 08:40 AM
Last Post: HansenCB_imp
