Accessory outlet
drodg33 Offline
USA
Threads: 24
Likes Received: 5 in 3 posts
Likes Given: 6
Accessory outlet
Does anyone have an accessory outlet installed that I can see a picture and where did you purchase one? I know Gerbing's sells one and so does Aerostitch. Thanks
11-11-2014, 01:36 AM
CIP57_imp Offline
Threads: 68
RE: Accessory outlet
I have had Powerlet outlets on most of my bikes, i put a direct line to the battery for heated gear and charging for the CB that attaches to the frame and tucks under the seat.
http://www.powerlet.com
[url=http://s1034.photobucket.com/user/cipolla57/media/power_zps8c9893ae.jpg.html][Image: 755d7ef3ad3f27ff4d79564be7c1a6e5.jpg]
11-11-2014, 03:44 AM
drodg33 Offline
USA
Threads: 24
Likes Given: 6
Thank you
11-11-2014, 06:16 AM
TINK_imp Offline
Threads: 36
I've been installing Coax "N" sockets on my bikes to run radar and GPS.
For heavy duty use, like electric vest, I plug into my Battery Tender SAE plug.
TINK
11-12-2014, 01:38 AM
HikerToo_imp Offline
Threads: 114
I have an Optimate battery charger with jack(s) coming off the battery, is that the same type of plug the Battery Tender has? and could be used to plug accessories into...
11-12-2014, 04:08 AM
Pauley Offline
Walnut Creek, CA
Threads: 14
Likes Received: 14 in 9 posts
Likes Given: 18
HikerToo - check the amperage ratings on the aftermarket wiring/fuse set up before connecting anything. I have a Battery Tender harness with an SAE connector wired to my battery with a 7.5amp fuse that I use with a Battery Tender and with a USB adapter to charge my cell phone if it needs it while riding. I also have a Firstgear heated gear harness with a 15amp fuse wired to my battery for my heated gloves (off topic, but oh baby those things are sweet). The instructions that came with the Firstgear stuff cautioned about using the Battery Tender SAE connection with coax adapter for the heated gear because of the rating. I had intended to have one harness for everything becasue I really didn;t want a rats nest and I didn;t see the need for both at the same time but gave that up when I realized the ratings were different. I have both harnesses wired to my battery and it's really not a mess at all. By some strange stroke of luck, I actually read the instructions and found that caution before I did something that would set my ride on fire. You may be well versed in this kind of tech, but I thought it was worth throwing out there. Happy motorcycling to you.
11-12-2014, 06:50 AM
Threads: 114
Thanks, ah yes, Optimate does offer connection accessories for their battery leads.
http://www.tecmate-int.com/ENG/u_accessories_power.php#
11-12-2014, 08:18 AM
  2017 OEM CB1100EX/RS Accessory Brochure rdprdp01 0 314 04-16-2025, 02:05 AM
Last Post: rdprdp01
  Accessory Removal Wagonpeddler_imp 13 927 03-22-2022, 05:22 AM
Last Post: Wagonpeddler_imp
  Ignition switch live accessory wire? ozigoo 10 758 02-18-2021, 02:32 PM
Last Post: ozigoo
  Accessory connector inside headlight bucket 17-CB-002 4 388 10-29-2018, 02:36 AM
Last Post: 17-CB-002
  Choice of Fog /Accessory Lights Ennsync_imp 5 457 10-16-2018, 05:20 AM
Last Post: Ennsync_imp
  Home-made Accessory 3rdbike_imp 9 851 05-10-2018, 11:17 PM
  Accessory recommendation for a long ride chandler_imp 22 1,441 06-27-2017, 11:15 PM
Last Post: Rollie Bruner_imp
  New accessory parts on eBay - Just posted. pekingduck 4 453 03-19-2017, 03:08 PM
  Accessory mod opinions please dsinned_imp 14 972 11-26-2016, 01:59 AM
Last Post: White Dog_imp
  A new accessory Moto Skiveez drodg33 24 1,621 03-07-2016, 06:42 AM
Last Post: Desert viper_imp
