Seat lock stuck problem
#81
I never have trouble getting the seat off, but getting it back on is another matter all together.
(11-21-2016, 08:27 PM)Cormanus_imp Wrote:
(11-21-2016, 08:25 PM)Blockhead_imp Wrote: Turn the key, pull the hook down and then: while holding the seat; push, pull, twist, jiggle, swear and the seat will eventually disengage.
if that fails, push, swear, pull, swear, twist, swear, jiggle, swear, rattle, and swear again. Good luck.
This is the same procedure that I use Thumbs Up
I have a question. Once the seat is off, does the latch move the correct amount?
I haven’t read all the threads but once I depress the latch I give it the old Fonzie hit on the back just like the old jukebox and mine pops open every time.And it’s a Corbin
(03-16-2019, 12:57 AM)Lord Popgun_imp Wrote: I have a question. Once the seat is off, does the latch move the correct amount?
Mine moves as much as the cable allows it which is not enough to make this process smoother so I will have to figure something out.
(03-16-2019, 02:03 AM)dsan1964_imp Wrote: I haven’t read all the threads but once I depress the latch I give it the old Fonzie hit on the back just like the old jukebox and mine pops open every time.And it’s a Corbin
I do the same on my Corbin seats and never have a problem getting the seat off or on.
I just pull up on the passenger strap on the standard stock seat (after unlocking with key + latch).
  CB1100 Idle speed instability problem ericlo69_imp 1,434 118,434 07-26-2026, 01:51 AM
  idle problem update 1973cb750 37 2,135 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Stuck Gear Linkage Nut — Can’t Loosen Without Twisting the Rod Narciso 5 1,675 10-10-2025, 09:24 AM
  "Seat Lock" cable unseated. 17-CB-002 10 1,014 08-27-2025, 08:19 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,263 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 660 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,809 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 856 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 1,885 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,505 10-08-2022, 09:18 AM
