Little by little...one moves forward with difficult tasks...with lots of patience...
(05-09-2018, 01:57 AM)pdedse_imp Wrote: Little by little...one moves forward with difficult tasks...with lots of patience...
Didn't have time to work on the bike as planned - worked a 13 hour day instead. I hate how working gets in the way of the really important things in life Big Grin
Job is nearly complete. All valve clearances are within spec and have been recorded on the valve clearance thread. All that is left now is to install the gas tank, seat, and side covers - will do that Monday or Tuesday.
Hope the fuel connection goes easily.
Does FSM advise any lubricant on o-ring?
On Sportsters (07 up) they can nick easily.
The FSM says ...press the quick connect fitting onto the fuel joint until both retainer pawls lock with a “CLICK”
If it is hard to connect, put a small amount of engine oil on the joint end.
I replaced the fuel line because I damaged the connection when I removed it (it wasn't cheap). I put a tiny dab of grease on the connector (engine side of joint) and it snapped together easily. I still think this is not a very good design. When disconnecting the fuel tank joint I had the legs of the connector compressed as far as they could possibly go (I used needle nose plyers) and this still was not adequate for the clips to disengage the hooks. That's when I resorted to forcing the joint apart with a screwdriver and damaged it.
Update: Buttoned the bike up tonight. Said a prayer, turned the key on and hit the button, and it started immediately! Initial idle speed was approx. 1250 RPM. Put 22 miles on the bike, mostly around town, but included a short (about 5 mile) stretch of freeway. The idle speed very quickly dropped to about 1,050 RPM, where it remained the rest of my ride. So it initially appears that the new IACV solved the high/low/stalling problem, as the bike ran perfectly, but it's too early to reach that conclusion. I need to put several hundred miles on the bike before I believe that it is fixed. I'll post some more information soon, including some pictures. Thanks to all the great forum members for their technical support and encouragement.
(05-15-2018, 03:29 PM)Dave_imp Wrote: Update: Buttoned the bike up tonight. Said a prayer, turned the key on and hit the button, and it started immediately! Initial idle speed was approx. 1250 RPM. Put 22 miles on the bike, mostly around town, but included a short (about 5 mile) stretch of freeway. The idle speed very quickly dropped to about 1,050 RPM, where it remained the rest of my ride. So it initially appears that the new IACV solved the high/low/stalling problem, as the bike ran perfectly, but it's too early to reach that conclusion. I need to put several hundred miles on the bike before I believe that it is fixed. I'll post some more information soon, including some pictures. Thanks to all the great forum members for their technical support and encouragement.
Congrats on getting the bike back together; at least you've done what you set out to do: you exhausted other possibilities, then took on the IACV AND checked valves. You're at exactly where you wanted to be at. Time will tell, fingers crossed for you.
Dave, you are running like a swiss watch!
thanks for the update and you are right about early days.
If things keep ticking over like this you will be in a very select group of owners that deserve a lot of respect.
Worship
max
Congratulations, Dave. Once again congratulations on your persistence and those of the forum members who have assisted and encouraged you.
I hope your bike is cured.
  idle problem update 1973cb750 37 2,150 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 900 10-22-2025, 02:11 PM
  Chain or sprocket problem ? The Gecko_imp 14 1,310 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 1,042 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 680 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,828 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,445 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,010 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
