Ok I went out and tested my 2014 DLX. Fired it up and it went to 1400 ish rpms normal cold idle. Dropped it into first and without touching the throttle let out clutch to just before engagement point and the idle went up to maybe 1700 rpms. Did this several times to verify. Let the clutch out any further and it starts pulling forward. Very Interesting.
Then I put it back in neutral and let it continue warming up until it got down to the 1050 ish rpms normal warm idle. Dropped it into first and without touching the throttle, let out the clutch to just before engagement and the rpms DROP to near 800 rpms. That's as low as I could get it to go before engagement started and bike started pulling forward.
So on cold idle a rise of near 300 rpms and on warm idle a drop of near 300 rpms by putting in gear and letting clutch handle out to near engagement point.
oh boy, after all that time eh? nice going ferret, that, of course, is news to me as well, can i suggest a video?
Wonder if we could call that an "easter-egg" ( computer term for hidden function ).
Would try it but just put a woolly blanket on my cb1100 for the winter season.
Thanks for trying that! max
yea I don't do video max. I barely do still shots.
I think the thing is, I have never tried to let out the clutch without my hand being on the throttle, (I mean why would you? lol) and I never put in it gear in full high cold idle mode. I let it warm up a couple mins, idle drops a bit and then I put it in gear and take off with my throttle hand adding in a bit of throttle like normal.
(03-12-2018, 08:32 AM)The ferret_imp Wrote: Ok I went out and tested my 2014 DLX. Fired it up and it went to 1400 ish rpms normal cold idle. Dropped it into first and without touching the throttle let out clutch to just before engagement point and the idle went up to maybe 1700 rpms. Did this several times to verify. Let the clutch out any further and it starts pulling forward. Very Interesting.
Interesting.
The neutral switch connects to ECM B33, which may trigger this.
The side stand switch connects to ECM B22, which is the only input I have found, thus far, for the ECM to kill the motor if side stand is down.
Like to see the ECM program. If ladder logic, then with rung comments.
(03-12-2018, 07:16 AM)SportsterDoc_imp Wrote: The clutch switch is normally open (lever out for engagement), so as it is released the switch opens, which seems to trigger the higher idle. Jumper the two clutch switch terminals should prevent the idle increase, as reported.
My 2014 standard was warm from this mornings ride, so I did some tests:
With clutch switch disconnected, connected or jumpered, neutral or clutch pulled, idle is a tad over 1,000 RPM.
As clutch is engaged (clutch switch disconnected, connected or jumpered), RPM starts to drop. Without throttle, it will drop as low as 750 RPM as bike moved forward.
For Bindir Dundat, confirm this is the 2017, which may have a different ECM program, compared to 2010, 2013 and 2014 models?
(03-12-2018, 07:15 AM)johnf514_imp Wrote: Just wanted to add my experience here. Same issue with idle rising when letting out the clutch in gear, but before any meaningful engagement. Also, the idle would typically rise just by putting the bike in gear, and holding the clutch in the same position (completely disengaged).
(03-12-2018, 05:45 AM)max_imp Wrote: Nice job mechanix, no doubt about the validity of the test, it proves the switch IS providing the input ( b22 sstand ) to the ecm, disconnecting it without even touching the lever causes the increased idle.
So why does it do that and is it a fault with the wiring?
+1 on sportsterdoc on the internal programming of the ecm, combined with bindir's findings i would agree that is the case, never noticed it before? could have easily missed it with all the enjoyment that riding such a nice cb1100 brings.
If it was a fault in the wiring it would persist when the bike is cold or warm, it does not do this and therefore unlikely to be a faulty ground, but still worth checking for corrosion etc.
If the negative battery cable has a bad connection it would quickly show up in a bad starting and dimming of the instrument cluster on application of the start switch at which point 150 amps flows through the cable and loosing 2 volts at this point could mean the difference between a good start and no start, this 2 volts would be 0.1 volt when the battery charges with 7 amps but would not have an effect because the sensor grounds come together on the frame at central points, engineers have discovered this ground pitfall and grouped the wiring accordingly ( check the wiring diagram ).
By the way i use my green neutral light as a battery tester, it dims as the bike starts, the more it dims the lower the battery capacity is, 2010 model.
So i would like to think of this as an undocumented feature honda has knitted into the later models to "assist" drivers in adverse conditions, ( but just never heard of this bahaviour and stand corrected/ like to hear from others as it could be a clue ) they just forgot to tell it to the printers of the manual.
Thinking about your explanation that this increased idle switch behaviour lasts for 4 miles longer than the original cold idle does make me think though, as far as i can work out the engine temp is sensed by the Engine Oil Temperature sensor below the throttle body, the other temp sensor is in the air intake after the air filter in the velocity stack chamber, but that should not change because it measures ambient temperature which does not change when the bike is driving.
From the video it appears that the iacv works fine and consistent in this part of it's travel range, it may be different in another part, though.
Briefly ; on startup the iacv is "reset" to the end of travel ( open, position 120 ) and then stepped to the cold position ( position 85 ) and gradually moves to it's operating position ( around 70 ) to maintain 1050 rpm, these are approx values to illustrate what happens, and conventional thinking is that the iacv has a problem around position 70 ( thanks popgun ) and produces the idle issue for reasons we are still trying to work out, it is quite hot in there during slow traffic and among other things may affect the magnetism in the permanent magnets in the rotor section of the iacv, weakening them, again ; speculation from me at this point
Have you noticed an increase in fuel consumption? that appears to be one of the symptoms associated with low idle syndrome.
Good video; max
In my case, yes I noticed a material increase in fuel consumption. My bike doesn't seem to do well in terms of fuel usage anyway (<40 MPG around town), but I was getting LFL before 90 miles in some cases with the high idle. Also threw off a lot of heat.
What model year?
Be helpful if the data to the left of the post (avatar, location, # posts, join date) also had model year or if everyone would include in the signature.
Sorry, should have included. 2014 EX
My 2013 w/ 24,000 miles always runs and idles great EXCEPT when cold; then it fast idles around 1500 (which is typical for the CB1100) but when I drop it into gear while cold the idle goes up to 1700-1800 but it only does that for a mile or so of warm-up. Then it idles when warm at 1050 all day.
Honda planted some idle variances into the bike that sense a variety of conditions and apparently Honda doesn’t advertise these nuances. When electrical connections get wet or corroded the signals controlling the idle give false signals and we call it “idle instability” and some owners got it worse than others. Tricky to trace.
Thanks for the confirmation 736cc, just checked mine from under the blanket and it ( 2010 model ) does not have increased idle when cold, we are now getting quite a list of owners that have this cold trick happening;
736cc;2013-----ferret;2014dlx-----johnf514;2014-----bindir dundat; cbf1000 2012-----mechanix 2014.
Is there a relationship between affected bikes and the way they are programmed?
In other words; do owners with ii issues have an elevated cold clutch idle as well?
and can an affected ( or in the future ) bike be identified this way? hmmmmm......
I don't have any idle issues Max, my bike cold idles at 1400 rpms, drops down to 1050 rpms when warmed up, has always done that and has never waivered from that. I hope that clutch dealie isn't a harbinger of problems to come.
We need to find some more guys to test theirs when cold.
My 2013 raises the idle just before the clutch engages when it is cold as well. However, it is just compensating for the additional load being applied while the clutch slips. It sounds like a feature that is working as designed.
I agree, these are highly engineered devices and looks like some sophisticated sensors and circuits are in play here.
I'm still wondering if the high idle/low idle issue is completely random or linked to a certain batch of VINs, with maybe a defective part used in production. Wish Honda had an answer.
  idle problem update 1973cb750 37 2,150 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 902 10-22-2025, 02:11 PM
  Idle a little rough and miss fire when revved johnnyH_imp 3 435 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,317 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 1,047 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 681 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,830 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,487 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,044 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
