Stock Exhaust Mod
Carguy1959_imp Offline
Threads: 8
RE: Stock Exhaust Mod
#61
Here is a picture of mine. I cut the snout off flush and drilled 3 1" holes. Then trimmed out th cap a bit.
06-24-2016, 01:12 PM
Catbird_imp Offline
Threads: 5
#62
(06-24-2016, 01:12 PM)Carguy1959_imp Wrote: Here is a picture of mine. I cut the snout off flush and drilled 3 1" holes. Then trimmed out th cap a bit.
What did you use to open the hole in the end cap? It's hard to tell from the picture, but it looks fairly uniform and finished (not butchered).
06-24-2016, 11:35 PM
Threads: 8
#63
I used a demel with a cut off wheel. Cleaned up the edge with a die grinder
06-25-2016, 10:58 AM
Catbird_imp Offline
Threads: 5
#64
I don't think I could do as well as you did.
I was thinking about removing the end cap, inverting & stabilizing it on a piece of scrap wood and then using a hole saw of the desired diameter. (still thinking)
06-25-2016, 10:29 PM
Biggin_imp Offline
Threads: 0
#65
(06-20-2016, 12:11 PM)dsinned_imp Wrote: Biggin, so what you did is effectively allow a way for the exhaust to escape directly out of the eight drilled holes thru the existing hole in the end cap where the muffler's tail pipe use to stick out? And you did this based on how the sound improved while riding with the end cap removed? Please provide a photo of how it looks now. TIA.
Sound based on having it running and pulling the end cap off with fast idle, to me is pleasant improvement have no thoughts of buying muffler now. Going to spend money on k & h seat
Sorry no pic, someone posted the same as my looks
Thanks. Oh by the way I hear no popping on decel
07-03-2016, 09:42 AM
dsinned_imp Offline
Threads: 22
#66
I was very tempted to follow your lead, but decided to go with an aftermarket slip on instead. This way I can always go back to 100% stock, which may be important if I ever sell the bike.
07-03-2016, 01:37 PM
Outlander427_imp Offline
Threads: 4
#67
I'm planning on doing this. I can't tell for sure but it appears that you cut off the outlet in addition to drilling the holes. Is this the case?
07-17-2016, 04:57 AM
TCinNC_imp Offline
Threads: 3
#68
(07-17-2016, 04:57 AM)Outlander427_imp Wrote: I'm planning on doing this. I can't tell for sure but it appears that you cut off the outlet in addition to drilling the holes. Is this the case?
You don't have to cut off the outlet. The OP just drilled holes in the end of the muffler with the end cap removed, and then re-installed the end cap (just as I did as well).
07-17-2016, 10:29 AM
darkangel_imp Offline
Threads: 2
#69
Hi, have anyone done this mod on 2104 cb1100 DLX? It seems the end of 2014 exhaustes are difference and I don't know how to open them. Please post a guide if youhave done it. Thanks!
10-31-2016, 04:28 AM
CBryder_imp Offline
Threads: 2
Stock Exhaust Mod
#70
So there I was with the drill in my hand for an unrelated project. What the he**! 6 x .5
Louder than I expected, but I'm sure it'll grow on me.
Sent from my SM-G920T using Tapatalk
11-15-2016, 10:43 AM
  Stock Mirrors MrBob_imp 5 598 04-11-2025, 03:33 AM
Last Post: balkanhound_imp
  Stock Muffler jbird06_imp 8 754 05-02-2024, 11:21 AM
  Stock exhaust or aftermarket header? milkmaster_imp 17 1,417 07-20-2023, 04:11 AM
  Decat stock pipes ozigoo 4 483 05-22-2020, 10:55 AM
  Stock vs. aftermarket exhaust LongRanger_imp 15 1,110 11-30-2019, 06:30 AM
  Shaved Stock or K+H Low GroovyBunny86_imp 18 1,588 06-18-2019, 12:58 AM
Last Post: BayAreaRick_imp
  Modify stock muffler? DBM_imp 2 361 07-30-2018, 05:08 PM
Last Post: FLYTYM_imp
  Anybody modify a stock 014' seat? el duque_imp 9 738 06-05-2018, 03:39 PM
Last Post: el duque_imp
  stock seat mod TCBronson_imp 6 633 10-03-2016, 06:19 PM
Last Post: ryanschillinger_imp
  Stock Honda Rack Frulk_imp 14 1,128 08-07-2016, 07:35 PM
