 Rotella T5 10w30 + CB1100 = HAPPY!!!
#61
(06-25-2023, 09:39 PM)m in sc_imp Wrote: I'm trying to see your point. Honda literally banks their reputation on reliability, they have for 60 years. why would they cut corners on the literal 'life blood' of their engines? Having have actually worked at a honda dealership years ago & gone thru some corporate service training, I can tell you they will absolutely take a financial hit (ie sidestep profit) vs damage their reputation. I'm pretty sure their oils are up to the task just fine of protecting their motors, and I certainly have never heard of an oil related failure aside from somebody not filling it enough. I read the info you posted. I also know that Honda will absolutely randomly have dealerships occasionally send oil in for lab testing, I know they did when I worked there (it was a car dealer though). They are absolutely aware of what's in their oil.
Another point is that ZDDP over a certain amount ppm will/can damage 02 sensors and ruin catalytic converters, hence why 'racing oils' or 'diesel oils' have more in them, because it isn't a concern. this is partially a reason why I DONT run VR1 in my CB (the 02 sensor), but do in my old cars. Its also why honda doesn't spec it, you really can't in an emission controlled vehicle. .02
Yes, my flat four air-cooled car uses a single weight SAE30 oil with high zinc content additive to try and give the camshaft/pushrod interface an easier time. When the newer style roller tappet came out in similar engines the oil recommendation was for a very much lower zinc content for the very reasons you mention.
Excellent points, thanks for taking the time to give a thoughtful reply.
My experience with the Honda motorcycle dealers near me has given me a very different impression of the Honda corporation than the one you came away with.
I like their designs, but I am not impressed with their ethics... Honda has made some very bad engineering decisions in the past 20 years. Innocent people have died.
If my experience with Honda was more like yours, I'd be more inclined to trust them.
Your point about ZDDP is well taken. I can’t guarantee that the amount of zinc in the T5 won't come back to haunt me, but I've already taken the plunge.
Do you know what the current limits are? Or what the limits were 20 years ago? It seems to me that the limits are a moving target based on EPA and/or political considerations...
I do know that my Eleven runs well on the T5 10w30, better than any of the MA listed oils Ive tried including the Honda GN4.
Thanks again for your detailed reply.
These are the notes on my SAE30 oil classed as "High Zinc Content" for my car. Zinc as ZDDP @ 500 ppm.
ZDDP (full name Zinc dialkyldithiophosphate) is a compound developed in the 1940s consisting of zinc bound to the anion of dithiophosphoric acid. They are soluble in nonpolar solvents, and the longer chain derivatives easily dissolve in mineral and synthetic lubricating oils.
The main use of ZDDP is as an anti-wear additive to lubricants, but over time their concentrations have been reduced to avoid damaging catalytic converters on modern vehicles. Crankcase oils with reduced ZDDP cause damage to, or failure of, moving parts lacking ‘full film’ lubrication in classic vehicles such as flat tappet camshafts and followers, which undergo very high boundary layer pressures and/or shear forces at their contact faces; and in other areas such as piston rings and gudgeon pins. The same ZDDP compounds serve also as corrosion inhibitors and antioxidants.
The plot thickens...
I was looking at the API classifications for T5 10w30 (because I'm a party animal... lol) and the new T5 jug now has JASO MA2 written on it!
Previously it was only the Rotella T4 15W40 and the T6 5W50 and 15W40 that received the JASON MA labeling.
T5 10w30 now includes it on the jug... Not sure about other viscosities.
That is interesting.
I wish they would update their product specification document on their official Shell Rotella T5 10W30 site:
https://rotella.shell.com/en_ca/products...sht-lr.pdf
(07-09-2023, 08:46 PM)GoldOxide_imp Wrote: That is interesting.
Agreed, but Shell is a huge company with multiple websites in multiple languages all over the world. The link you provided is from Canada and is dated 2017, six years ago.
I found a bottle in Walmart here in Texas with the JASO MA2 cert on it. I'm certain that the bottle I purchased last Spring didn't have it.
I also discovered that the Mobil1 4T 10w40, a respected motorcycle oil with the JASO certs and cute motorcycle pics on the bottle, has 1800 ppm of zinc... More than twice what's in the GN4, and a third more than what's in the T5 10W30.
Not a great pic, but it's something from Walmart showing the JASO MA/MA2 spec on a T5 10W30 jug....
Awesome Yata-Garasu.
Will keep my eyes peeled for it up here.
(07-12-2023, 12:39 AM)m in sc_imp Wrote: so who's doing a flat tappet cam conversion here to necessitate this much zinc to be needed in a CB1100 motor? lol. also remember that when any of this gets into the combustion chamber, and some always does, it creates actual ash, which isn't a real good idea to be running thru the motor.
Honda's own GN4 10w40 had 1200 ppm of zinc as recently as 2007. Did all the pre 2007 bikes have flat tappet cams?!
Rotella T6 5w40, a forum favorite for colder climates, has long had over 1100 ppm.
I was surprised to learn that Mobil 1 4T is 1800 ppm, but no one is complaining about Mobil 1 4T necesitating a cam conversion!
I can understand wanting to protect the catalytic converter, but the cam conversion claim is over the top!
Current GN4 numbers are just under 900. T5 is just over 1100. It's within 300 ppm, and the T5 is conservative compared to Mobil 1 4T.
If the zinc numbers were as critical as you're claiming, Honda would have specified that in the owners manual.
Honda recommends a 10w30 oil that meets the JASO MA2 spec.
That's exactly what Rotella T5 10w30 is.
(07-12-2023, 06:06 AM)m in sc_imp Wrote: i'm just trying to figure out why YOU think its so important to have so much zinc in there. 2007 was 16 years ago, they changed it for a reason since then. its bad for 02 sensors over time, period. some reports claim 50% reduction in life of an 02 sensor. You don't need to justify to anyone why you want to run it in your bike, do whatever you want. But, there are downsides to it as well, which doesn't seem to be a concern to some. But, it bears mentioning.
The local shop here which services mostly high end dirtbikes, and a lot race, got so tired of his customers droning on and on about running rotella, he started carrying it just to give them what they wanted if they requested it. high strung 4 stroke motocross singles. zero benefit over anything else. He doesn't care if you bring in your own oil, really. so its not a selling expensive oil thing. I've seen the results 1st hand. It doesn't do anything better except maybe cost a little less, and obviously thats the main driver here and with mos tpeople. . The BIGGEST thing is to change the oil regularly.
To quote Blackstone Labs "The zinc in your oil comes into play only when there is actual metal -to-metal contact within your engine, which should never occur under normal operating conditions. (hence the flat tappet comment) However, if you race your bike, or occasionally play tag with the redline on the tach, the zinc is your last line of defense. Under extreme conditions, the zinc compounds react with the metal to prevent scuffing, particularly between cylinder bores and piston rings. However - and this is the important part to remember available research shows that more zinc does not give you more protection, it merely prolongs the protection if the rate of metal-to-metal contact is abnormally high or extended."
so.. why again is it needed in the CB motor at 1000 ppm+?
Did I say that the CB1100 needed a high level of zinc? Nope.
I said that there are plenty of other well respected motorcycle oils with comparable or higher zinc levels (M14T).
Neither Honda, the industry at large, nor you seem to be going after those other oils for damaging 02 sensors or catalytic converters.
Originally you took exception to the fact that it didnt say JASO MA2 on the bottle. Now it has those letters. Then you took exception because I didnt want to buy 5 quarts of oil if I only need 3.8.
Now you're trying to take exception with zinc levels.
The current API spec lowering zinc below 1000 for gasoline engines with catalytic converters didnt take effect until 2020, three years after Honda stopped selling the CB1100 in North America.
Rotella T5 10W30 (and T4 15w50 and T6 5w40) all have a comparable amount of zinc as most other commonly used JASO MA2 motorcycle oils available today.
Honda recommends 10W30 oil that meets the JASO MA spec.
Rotella T5 10w30 is one such oil.
A side note:
Curious as it might seem, the Moto Guzzi V85TT requires a JASO MA/MA2 SAE 10W60 engine oil, even though it uses a dry clutch.
I wonder what their motive is?
   Rotella T6 -> 5w40 vs 15w40? Yata-Garasu_imp 28 2,587 08-02-2024, 11:36 AM
Last Post: Ollie
  10w30 vs. 10w40 Boonetown_imp 30 2,807 07-31-2024, 11:05 AM
Last Post: Pauley
  Rotella T6 - Now in 10W30! Yata-Garasu_imp 10 991 10-10-2023, 10:39 PM
   Actual Oil Capacity of the CB1100??? Yata-Garasu_imp 43 3,696 07-26-2022, 11:26 AM
   front suspension oil change CB1100 EX 2015 (23700 kms). recommendations ?. Alfgaxatico_imp 7 725 11-23-2020, 07:34 AM
Last Post: Alfgaxatico_imp
  Shell Rotella Snythetic 5w40 oil in CB1100 capttwb136_imp 38 2,933 09-04-2016, 08:47 PM
Last Post: capttwb136_imp
