 Rotella T6 -> 5w40 vs 15w40?
This question is aimed soley at people who have used Rotella in their CB1100s.
I have used T4 15w40 dino oil with great success in my Nighthawk 750 (inline 4) and Shadow 750 (VTwin).
Honda recommends 10w30 for both of those bikes, but the Vtwin definitely seems to prefer the T4 15w40 over the Honda 10w30, ie, smoother shifts and quieter engine. The Nighthawk doesn't seem to care either way.
The CB1100 is very similar to the Nighthawk. I'm currently using Honda 10w30 in the CB1100, but I'm thinking of going with the 15w40 T6 on my next oil change.
I was initially considering the T4 in the CB1100 too, but according to Shell, the T6 15w40 flows better at cold temps than the T4, and has better shear protection.
I like the idea of a full synthetic in an oil cooled bike.
Since I live in Texas and never ride when the temperature is below freezing, I think the 15w40 should be fine, but I'm curious about the 5w40 too... I'm wondering if there would be any benefit to the 5w40 besides just the increased flow at low temps.
From what I have seen, both the 5w40 and the 15w40 Rotella oils have a weight of around 15 at 200 F, so it probably won't make much of a difference either way... But I seem to recall a thread where people said the 5w40 made the engine a bit noisy.
Anyone with experience who could shed some light on the subject? Thanks in advance!
I used Rotella T6 5W40 with no known side-effects or extra noise - in fact, the lump was quieter and gear shifting remarkably smoother compared to GN-4. Sub-zero winter riding also benefited being 5W and synthetic.
I would have never considered 15W40 for the CB1100, especially for cooler riding weather.
(06-14-2021, 09:33 PM)GoldOxide_imp Wrote: I used Rotella T6 5W40 with no known side-effects or extra noise - in fact, the lump was quieter and gear shifting remarkably smoother compared to GN-4. Sub-zero winter riding also benefited being 5W and synthetic.
Thanks. I imagine the 5w40 would give you a noticable improvement in gas mileage too.
I've used Rotella T6 synthetic for years in all my bikes with good result. When I got my 2013 CB1100 the transmission was a bit noisy and the shift from second to third balky at times. This continued with the 2nd an 3rd oil changes while I was using the Honda brand synthetic 10W-30. I got a factory service manual which said that 10W-40 oils were an acceptable alternative so next change I went back to my old favorite Rotella 5W-40. That was the end of the balky shift and a slight reduction in noise. Whether the Rotella oil was the solution or the transmission finally broke in I don't know. All modern oils are good but the Rotella can be found for so much less than branded motorcycle oils.
Yes. And the fact that my Shadow 750 runs noticably better on Rotella T4 than on Honda oil tells me that Honda is good at engineering motorcycles, while Shell is good at engineering motor oils.
I was looking at the 15w40 simply because of the increased shear resistance, and because the T6 supposedly flows very well at low temps for a 15w oil. If you folks are using the 5w40 T6 with good results, I am willing to go that direction too.
I understand that Honda GN4 oil is semi-synthetic
(06-20-2021, 08:32 PM)Enzofour_imp Wrote: I understand that Honda GN4 oil is semi-synthetic
This common version is conventional in North America:
5W40 here as well with good results
(06-21-2021, 09:39 PM)sonnyb_imp Wrote: 5W40 here as well with good results
Thank you Sonny, I see that you're in Fort Worth, so pretty much the same climate as myself in Dallas. How many miles have you been running the T6? Did you ever consider the 15w40 version? Do you ride in the winter as well? What kind of drain interval are you using? Thanks for the reply!
Just a quick update.
Installed the 15w40 T6, full synthetic.
After running the dealer-installed GN4 10W40 for a season and averaging about 40 mpg, with an all time high of 46 mpg once, I was very pleased to see my mileage has improved to 50 mpg with my first full tank running the 15w40.
The old Honda GN4 10w40 had about 3500 miles on it, and had the viscosity of coffee when it came out.
I'm interested to see if the mileage will continue to be this good or if it's just a fluke.
Even comparing to my previous record of 46 mpg on the GN4, 50 mpg is almost a full 10% improvement. Compared to my average of 40 mpg, it's better than 20%!
I am not sure, but it's possible that the engine is a little louder with the 15w40 compared to 10w40. This could simply be an expectation bias as I anticipated that the 15w40 might be louder, and I was fully prepared to dump out the 15w40 immediately if the mileage was poor.
Luckily the mileage improved, so I will be sticking with the 15w40 for at least a little while longer.
I wanted to share my experience as there seems to be a bit of confusion on this topic, and even some fear mongering when it comes to using non-Honda oils.
I know a lot of people here use the 5w40 T6 instead of the 15w40. I picked the 15w40 due to it's improved sheer resistance, and the fact that I rarely ride below 32F, and never ride below 22F.
If the 15w40 had caused worse mileage, I was considering the 10w30 Rotella T4, a semi synthetic at the exact weight spec'd in the owners manual. If I was in a colder climate than Texas the 10w30 might be my go-to oil.
Anyhow, so far so good with the 15w40 T6.
  Rotella T6 - Now in 10W30! Yata-Garasu_imp 10 948 10-10-2023, 10:39 PM
   Rotella T5 10w30 + CB1100 = HAPPY!!! Yata-Garasu_imp 73 7,236 07-12-2023, 01:00 PM
  Shell Rotella Snythetic 5w40 oil in CB1100 capttwb136_imp 38 2,605 09-04-2016, 08:47 PM
Last Post: capttwb136_imp
