#61
Naah, ignition on/off doesn't solve it, you gotta use the kills switch and the bikes idle transform from cuss to how its supposed to act...
What also seems to help is doing the TPS reset (ignition on but don't start the engine, apply full throttle than throttle to zero position, repeat this twice, ignition off) but this takes too long so I rather use the kill switch, especially when I'm in city traffic.
Can you see me standing there in the traffic jam doing the TPS reset procedure :-)
Yeah, I shared the video on all 4 major CB1100 facebook pages.
And on all major CB1100 forums on the net (this one, UK one, French one)
Not the German one yet, too difficult language and too lazy to use Google Translate.
And on the ADV forum they also have a dedicated CB1100 forum:
http://advrider.com/index.php?threads/20...00.820439/
(05-12-2016, 07:46 PM)kmoney_imp Wrote:
(05-12-2016, 03:27 PM)Riko_imp Wrote: Some mechanics i spoke with strongly follow the hypothesis its bad lambda sensors.
That could explain the issue.
Giving wrong info to the ecu causing it to idle low.
Doing this only after its on temperature, so not immediately.
Using the killswitch resets the values send from the sensor.
No error codes on the ECU.
Thinking about perhaps going the O2 eliminator way....
But later today I'll to disconnect the battery since that solved the issue for someone according to my taiwanese facebook connections..i doubt this is true, but I can only exclude that option by trying.
Most EFI systems run idle and WOT in open loop mode, and only use O2 sensors for part throttle mixture control. It's possible the CB is different, but I would be surprised if it was the oxygen sensor causing this problem.
isn't there a difference with the STD and the dual exhaust cb's?
the EX has 2 sensors and both have the identical same function?
I am not technically skilled but I will copy paste the text from a mechanic that helped me in the past and he said some stuff about those lambda sensors and why this could be reason.
He also said something about an open or closed loop mode.
Will be continued.
(05-12-2016, 10:26 PM)Riko_imp Wrote: Naah, ignition on/off doesn't solve it, you gotta use the kills switch and the bikes idle transform from cuss to how its supposed to act...
Will be continued.
de eerste 15 minuten zullen de lambdasonden geen invloed hebben
want dan zijn ze niet warm
dan draait de ECU niet in closed loop
dat wil zeggen, dat hij zijn inspuiting aanpast aan de waarden van zijn lambda sonde
dan gaat hij enkel naar het kenveld kijken.
translated he does say more or less the same as you say:
the first 15 minutes, the lambda sensors will have no effect because then they are not warm
the ECU is not running in a closed loop
this means, it adapts the injection to the values of lambda probe
then he will only look at the diagram
(05-12-2016, 12:18 PM)Elipten_imp Wrote: That is just plain unacceptable! I hope Honda solves the issue fast. Strange only on the EX models do far.
My 2014 standard started doing it again last night.
The idle would drop down to around 500 rpm and then slowly creep back up to around 1000 rpm. I tried the throttle reset mentioned here and that seemed to help.
I originally chalked up the last time the idle problem happened to bad gas but I've only been using tier 1 gas since then. I also add some Techron or Seafoam about once a month.
I'm going to take the bike out later today and see how it is. If it acts up again, I'm going to the dealer and insist that he check it out. My bike is still under warranty until July.
I'm just concerned as this might become a safety issue with possible nasty repercussions.
had a similar issue on mazda protege 5. had to replace the EGR valve a few times.
hope this helps.
hope this helps.
hope this helps.
Thanks for the heads up.
I just got back from a ten mile ride and the idle seemed stable. I'm still going to talk to the dealer about it.
I should also add that the bike isn't running rough when the unsteady idle happens. I suspect it might be something in the electronics dept.
a little update.
So, I disconnected the battery and than reconnected it, but I cannot make conclusions yet.
I rode for about 1 hour in the city, however it was late in the evening so there was virtually no traffic and it is also cold outside, like 11° C...the idle issue seems to be sensitive for warm weather and heavy stop and go riding...
Although I had no problems during my ride after I reconnected the battery I will wait for final conclusions after a ride in warmer weather, and if I encounter no issues, than I would think reconnecting the battery is indeed a solution for this issue...but for now its too early to say.
Unfortunately the weather will be cold the coming days here, so I will have to be patient. Smile
Its not the first time I heard that reconnecting a battery can solve some electronical issues (wich is the case with mine).
I heard stories like that about BMW cars that stall and after reconnecing batteries the issues seem to be gone.
Anyhow, I'll keep you all posted how the bike holds up.
hope this helps.
it seems that this was not the right solution than...
hope this helps.
hope this helps.
hope this helps.
did you notice, like the rest of us with this issue, that the problem manifests itself when riding in the city with lots of stop and go movement and in warmer weather? lets say 20°C and above?
if not, try to ride in those conditions only....
hope this helps.
hope this helps.
hope this helps.
the issue with the car happened within the first 2 minutes of starting and only if coming to a stop ,(like a stop light) . the idle would just drop, no rough running. never happened after being warmed up.
it was a known issue that the EGR valve went bad and needed replacement. the manufacturer decided not to do anything about it. had the car over 10 years so yeah, a few times.
okay, reconnecting the battery didnt prove to be the solution...so looking forward to the moment I bring the bike in at the dealers
(05-13-2016, 08:35 AM)Riko_imp Wrote: a little update.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
hope this helps.
I do a lot of city driving mixed with some freeway riding. When the problem started again the other night, it was cool out and I was on the freeway. I have not detected any pattern in the riding conditions yet.
I watched your video and my bike doesn't stall when the idle becomes unstable. The idle drops down to 400-500 rpm and then slowly climbs back up.
that is indeed very low...what happens at the moment the needle is on 400-500rpm if you rev the engine
very important to rev it at that low rpm...
in my case, that would be the moment the engine would drop furter to stall...
I will try one last thing, disconnect the battery overnight....it seems that ECU's tend to recalibrate themselves when the battery is disconnected for a long time...
  idle problem update 1973cb750 37 2,030 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 842 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 516 02-13-2025, 06:25 AM
  Idle a little rough and miss fire when revved johnnyH_imp 3 408 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,206 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 940 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 631 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,529 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,016 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,557 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
