Poll: How many are having problems with rear Brakes?
#61
Does your non-ABS model have the proportional valve on the left front rotor? I'd always thought both models had Linked Braking System (LBS).
Nope no proportional valve and only ABS is linked which was the main reason I bought my non ABS
Would someone with an ABS/ linked unit please verify this?
The linked system is only on the abs models. It is easy to test. Put bike on centerstand. Make sure sidestand is up. Start bike. Put it in gear and let out clutch. rear wheel will spin. Pull in clutch and grab front brake lever. If it is linked it will stop or slow the rear wheel.
Now....
Turn off bike and have someone put weight on back, getting front wheel off ground. Now manually spin the front. Now depress the rear brake pedal. If you have linked brakes the front wheel will slow or stop.
The linked system/combined braking is one reason why I too shy'd away from an ABS model (which was my original intent).
(08-10-2013, 12:03 PM)The ferret_imp Wrote: Would someone with an ABS/ linked unit please verify this?
Now....
You're almost correct. There is a proportioning valve (very easy to see on the ST's left front caliper. Merely pulling the brake lever, while the front tire is spinning in the air, will not activate the valve. The brake disc has to have enough force against it (like a tire slowing on pavement) to have the valve depress, which will then activate the rear brakes of the bike. You could also accomplish this by getting the front tire in the air, pulling the brake lever hard enough to stop the tire, then manually apply enough force against the tire/wheel (forcing it to turn) to see the proportioning valve push into the assembly. Then, your back tire will stop spinning.
These show the differences between the std and the ABS models for the brake routing.
[Image: d3bd3145f9f0bd007918c127a78d02fa.jpg]
[Image: 3c8d12c53cac74bb4e168eb30761fd54.jpg]
[Image: b268e516348f66692fd04e8138cb2f6b.jpg]
[Image: a7755dd40094636f99f2a4932fb3ead1.jpg]
[Image: 53f8ab41dcbfa6b69cba1b0d46864321.jpg]
[Image: ecfd46d28dcc39551c18ae2611bdf423.jpg]
Thumper yes there is a proportionong valve on my ST, no such valve on my CB. To test proprtioning valve/ linked brake on thie ST I put it on centerstand lay next to bike on left side, spin rear wheel with my foot and manually push proportioning valve foward the front. After proprtioning valve/ linked brake stops wheel, I let go and wheel will spin again.
Ferret, I have ABS and I did the test you requested. The rear brake stops the front and rear wheels. The front brake only stops the front wheel. I believe this is the way linked brakes are supposed to work.
(08-11-2013, 10:38 AM)terrydlargo_imp Wrote: Ferret, I have ABS and I did the test you requested. The rear brake stops the front and rear wheels. The front brake only stops the front wheel. I believe this is the way linked brakes are supposed to work.
+1, that's how the Combined ABS works on the CB1100.
Ahhh very good, Thanks Terry. So on the linked/ABS model equipped bikes, ..the front lever activates the front brake only. The rear pedal activates the rear brake AND some of the front brakes.
On the NON ABS the front lever activates the front brake only and the rear pedal activates the rear brake only.
Thanks, clears it up definitively for me.
  Front brakes squeal...this feels like a saga in the making VLJ_imp 108 10,315 11-17-2021, 04:33 PM
Last Post: j3gq_imp
  2020 Poll - forum member age Guth_imp 100 8,061 04-22-2021, 01:36 AM
  Problems with the website Randy B 17 1,259 03-13-2021, 12:21 PM
  motor cycle magazine subscription problems Houtman_imp 4 504 01-02-2021, 12:21 PM
  imgur problems? pdedse 2 338 09-17-2019, 04:07 AM
  Common problems experienced with CB1100 on road? run-tmc_imp 28 1,841 05-28-2018, 08:04 PM
Last Post: DaSwami_imp
  ADVrider poll on classic motorcycles pdedse 44 3,031 11-29-2017, 02:51 AM
Last Post: SportsterDoc
  02 sensor eliminator poll TCBronson_imp 15 1,187 08-28-2017, 05:41 AM
Last Post: Toddman_imp
  2017 CB1100 EX ABS brakes 17-CB-002 5 392 06-11-2017, 12:07 PM
Last Post: 17-CB-002
  Anti lock brakes Mikestib1_imp 29 2,304 01-08-2017, 02:54 PM
Last Post: flynrider
Users browsing this thread: 12 Guest(s)
