2017 Gas Tank on a 2013?
peterbaron Offline
Likes Given: 997
RE: 2017 Gas Tank on a 2013?
#51
(06-29-2017, 07:06 AM)PowerDubs_imp Wrote: No, I literally meant a spot where you had to type in your year & model of bike and it showed in the left area under the avatar.
From your picture alone I have no idea what year your bike is....
I am already done with mine
P.
(06-29-2017, 04:00 AM)PowerDubs_imp Wrote: Would be nice if we could require people to enter their year bike and have it displayed under the avatar on the left. Some other forums require this- either bikes or cars- and it is helpful in discussion- as is location.
06-30-2017, 09:28 AM
chandler_imp Offline
Threads: 11
#52
I put mine in my signature. Doesn't that accomplish the same thing?
2013 Honda CB1100
06-30-2017, 09:57 PM
peterbaron Offline
Likes Given: 997
#53
[quote='peterbaron' pid='176876' dateline='1499168181']
[quote='peterbaron' pid='176239' dateline='1498648174']
[quote='noroomtomove' pid='176235' dateline='1498646318']
28th of June 2017
G'day Peter, i'm interested to hear how far you get on a tank. I have ridden the tank to empty three times, twice as part of a plan close to home and carrying some extra fuel. The furthest is 314.5 km this was not an endurance attempt. Fortunately for me a FarRider came to my aid and I got to rendezvous with the rally Down Under later that afternoon carrying the recently purchased fuel can.
My bike was built in 2011.
Regards
Hi there, results will be coming soon... we presently have rain every other day, so I do not ride for pleasure.
Mid test, up to 100 km/h - slow roads = after 250 km, 2 solid gas gauge bars and 3rd flickers from time to time.
This Sunday, weather looks promising, and I should be able to make 600+ km.
Accuracy will be up to 90%..'cuz do not remember exact amount of gas pumped into gas tank = pumped 2x at the same time/pump
Peter
'13 CB, 42.5 K
Hi,
TEST CONDITIONS:: 13' CB1100ABS- 5 speed, 43K, 17 L gas tank as per Takashi/Samurider, use 10W40 full synthetic oil, ambient +25-30*C, engine start temp +20*C, several, natural start ups and stops, tires:: Pilot RD 3 - F= 120/70/18, R = 160/60/18 & spec pressure, NO ECM/engine modifications = stock, roads:: 70% back roads and up to 100km/hr & 30% hwy with higher speed, operating RPM in 5th gear 3000 - 4500 accordingly, gas used:: 91 & 94 octane, refuelling:: on side stand. Have a windshield .
TEST # 1::
Filled gas tank ( no topping), rode certain distance , 2 bars on gauge dropped to 1 fuel bar + rode another 20 km (last bar still not flushing) = 320 km distance ridden and 14.2 L refueling with moderate topping.
TEST #2::
Rode 395.3 km, last fuel bar flushing for 15 km ( but before gassing, bar momentarily became solid ??), I am more than certain, I would pass magic 400 km !!!!!!! Tongue
https://s4.postimg.org/glzbqngx9/Tank_0.jpg
Refueling with deliberate/several times topping and tank took 16.5 L = WOW! ... now started testing the 3rd time. During this, 16.5 L refueling, there was no gas leak from overflow/breather tube from under my bike, so I think there still was 0.5 L of old fuel = total now in tank = 17.0 L Banana
https://s22.postimg.org/6bkx313e9/Tank_1.jpg
https://s13.postimg.org/3xlwaaplz/TANK_2.jpg
https://s18.postimg.org/vl9521ywp/TANK_3.jpg
NOTES/PRESUMPTIONS:: If a rider has throttle discipline (I don't) up to 3300rpm in the 5th gear, rides nonstop a the hwy, I believe that 400-450 km distance is realistic....and this might be test # 4 BikerThanksCelebrate
Cheers,
Peter
07-04-2017, 02:02 AM
pekingduck Offline
Southern California
Threads: 41
Likes Given: 39
#54
A 2017 gas tank showed up on eBay a couple days ago for $300. That seems like a pretty good deal. Item 122751719701. Unfortunately I just bought a black tank for my 2013.
10-13-2017, 03:10 PM
swifty_imp Offline
Threads: 1
#55
So I've been reading this and no one has said the 2017 tank will work on the 2013 (unless I missed a post) I also see that the gas cap looks different so the one off the old tank will not work.. The Japanese tank if I remember makes the bike look like an original 750 four. Anybody have an answer as I do a lot of long distance riding and my range is 120 miles on the tank and thank God for the Corbin set..
11-24-2017, 09:16 AM
Likes Received: 880 in 482 posts
Likes Given: 1,016
#56
swifty, check out [url=http://cb1100forum.com/forum/showthread.php?tid=11505]this thread of chync's. He's put a 2017 tank on a 2014 and I assume it's a standard, which suggests to me that it will fit on a 2013.
use2be might be able able to tell you the capacity of the Whitehouse tank—that's the one that looks like the original CB750 tank.
peterbaron has also put on a larger tank. There's discussion about it somewhere in [url=http://cb1100forum.com/forum/showthread.php?tid=10544]this thread. You'll also be interested in the opening posts, I suspect.
11-24-2017, 10:56 AM
use2b_imp Offline
Threads: 39
#57
Whitehouse tank is 4.7 Gal
11-24-2017, 11:14 AM
jedd_imp Offline
Threads: 27
#58
I aint gonna lie....
i want a 2017 gas tank real bad too...
just so I can paint it -exactly LIKE THIS~!
[Image: 0b0324e4db864e5476042c0556588739.jpg]
That gold color really shows off the curves around the knee area.
11-26-2017, 12:09 AM
noroomtomove Offline
Threads: 16
Likes Received: 4 in 3 posts
Likes Given: 19
#59
Information now in another thread.
02-01-2018, 07:32 PM
Guth_imp Offline
Threads: 125
#60
jedd, to my eye the gold one is by far the best iteration of the CB1100 RS.
02-02-2018, 06:48 AM
  Wire colors not matching the diagram (2013 A / 2017 NA)? LayerCake_imp 16 1,387 05-30-2022, 05:45 AM
Last Post: LayerCake_imp
  Ignition Starter 2017 on 2013 Bike cb1100_dude_imp 24 1,678 08-22-2021, 12:35 AM
Last Post: domeular_imp
  Tank pad for 2017 RS Endeavour_imp 0 216 08-16-2020, 06:32 AM
Last Post: Endeavour_imp
  Poll: Limited or black 2017 tank? Ferrealls_imp 20 1,583 04-10-2018, 06:07 AM
  New 2017 RS Tank Rasher_of_bacon_imp 1 249 11-29-2016, 11:28 AM
  Removed tank stickers, installed clear tank protector ryanschillinger_imp 6 631 07-01-2016, 12:09 AM
Last Post: Guth_imp
