Chain Cleaning - Methods and Products
#51
(07-13-2016, 03:51 AM)DJS_imp Wrote: there is also this page (not a video).
http://advrider.com/index.php?threads/ch...ts.345397/
That's the link I always point to when someone asks about chain cleaning products. Keith really took the time and care to make a thorough test of various potential cleaning chemicals.
Riko, he didn't test brake cleaner, but another seemingly innocuous substance, carb cleaner, turned out to have a very bad effect on the O rings tested.
Brake cleaner shouldn't hurt rubber, as it's designed not to effect the rubber components in brake systems. That said, that stuff is strong, and I don't know if I would want to spray it on my chain.
I would suspect brake cleaner, not to damage the O-ring rubber, but to went thru the rubber sealing and destroy the grease, which is encapsulated inside the chain by the O-rings.
Brake cleaner is a highly volatile solvent.
I didnt say I would use carb cleaner, but brake cleaner.
As pointed out even by the AVRIDER test, break cleaner seems to be harmless, it certainly did not show visible harm for the O rings, let alone confirm the malicious consequence I read on boards about the topic.
If brake cleaner was indeed that bad, the "test" would at least show some hints of that.
(07-13-2016, 01:44 PM)kmoney_imp Wrote: Brake cleaner shouldn't hurt rubber, as it's designed not to effect the rubber components in brake systems. That said, that stuff is strong, and I don't know if I would want to spray it on my chain.
it certainly is the best cleaning solution for all kinds of dirt on your chain.
Strong and a clean method since it evaporates in an instance.
The first and only time I used it a few weeks ago, I couldn't believe my eyes Smile
Just an FYI, he didn't test brake cleaner. The only brake product tested was DOT4 hydraulic fluid.
Let us know how the brake cleaner works out. That stuff is an excellent grease cutter.
aigth, will let the board know for sure
Is it brake cleaner or brake fluid that will eat the paint off of anything it touches?
(07-15-2016, 04:41 AM)Shinchan_imp Wrote: Is it brake cleaner or brake fluid that will eat the paint off of anything it touches?
That would be brake fluid.
brake cleaner! never use that stuff on your tank for example
i believe the instructions actually state this
  Cleaning exhaust headers. meowguy_imp 26 2,359 08-12-2025, 03:13 PM
  Cleaning the engine fins Ayrshire Dunx_imp 1 268 11-15-2021, 08:07 AM
Last Post: j3gq_imp
  Cleaning Chrome Headers DAC 7 643 02-09-2019, 04:31 AM
Last Post: Nortoon_imp
  Cleaning question Cormanus 26 1,700 02-08-2019, 03:04 PM
  cleaning the chain el duque_imp 11 821 09-11-2018, 08:31 PM
Last Post: DBM_imp
  Winter Bike Cleaning emptysea 27 1,885 03-07-2018, 11:38 AM
  FW1 cleaning wax RLS_imp 4 517 12-06-2017, 11:56 PM
  Electrical plug contact cleaning and maintenance curlyjoe 6 563 01-21-2017, 06:14 AM
  Oil Eater as effective cleaning agent cbdtran_imp 2 321 10-11-2013, 05:21 AM
Last Post: gcarper_imp
  Cleaning my CB1100 Greg Brooks_imp 22 2,665 08-22-2013, 11:22 AM
Last Post: MotoMichael_imp
