how long is the lubricating oil replacement cycle
#51
(01-29-2019, 03:30 AM)GoldOxide_imp Wrote:
(01-29-2019, 01:43 AM)Flynrider_imp Wrote:
(01-28-2019, 11:36 AM)GoldOxide_imp Wrote:
(01-28-2019, 11:11 AM)DBM_imp Wrote:
(01-21-2019, 01:28 PM)The ferret_imp Wrote: I believe I pay about $35 for a gallon of GN 4 and an oem filter
I pay about $30.00 for a gallon of full synthetic Shell Rotella and a OEM Honda filter.
Those numbers make sense fer 'merican prices.
What is the oil grade of the Shell Rotella? Walmart?
I suspect he's using Rotella T6 5w-40. It's the only full synthetic Rotella that meets the JASO-MA spec required by Honda. They also make a non-synth version (T4) in 15w-40 that meets the spec.
I usually buy the gallon jug of T6 at Walmart for around $21-$22.
Thanks Flynrider.
The 15W40 makes sense in the Arizona hot season. I have considered the T6 5W40 for more northern climate.
No real difference for me. Both types are 40 weight when hot. True that the 5W is better if you're riding in really cold weather.
I actually used to use the non-synth 15w-40 version, but I found through oil analysis that the non-synth was breaking down much faster during the blazing hot months of summer. Tests I ran on the full synth T6 showed that it held up much better, so I just switched to using that year round.
Thanks Flynrider.
  CB1300 headlight bucket replacement spechg 5 403 03-16-2026, 10:12 AM
  HISS Key replacement UK Davidjill_imp 12 1,040 01-19-2026, 05:09 AM
  Rear brake pad replacement LongRanger_imp 39 3,956 05-03-2025, 10:45 AM
Last Post: Delphisa
  Fork Pipe replacement suggestions danieljrmurray_imp 3 523 10-09-2023, 02:31 AM
Last Post: danieljrmurray_imp
  Fuel filter replacement Mafd2_imp 36 3,008 02-11-2023, 01:54 AM
  Long shift lever Sam Mac_imp 1 275 02-08-2023, 08:30 AM
  Replacement Battery dave 54 4,499 02-04-2023, 12:41 PM
  2013 replacement wheel Randy B 8 832 11-13-2022, 10:32 AM
Last Post: Randy B
  Clutch replacement advice misterprofessionality 31 2,719 06-11-2022, 05:51 PM
