New rear tire or both new tires?
#41
(05-06-2021, 11:42 AM)GoldOxide_imp Wrote: Hey Whoops: Also keep in mind pressure drops in the tire as temperature falls and vice versa without going anywhere. The difference is typically a few pounds, unless of course the temperature drops to below freezing.
Yep, and after it cooled it was two pounds down. So this is a temp fix at best.
(05-01-2021, 08:14 AM)Whoops_imp Wrote: My 2014 Std still has the original factory tires with a whopping 780 miles on them now. My back tire started feeling squishy today and I could hear a ticking at low speed. I had a guess as to why.
I made it home at a very slow speed (<25/mph). When I went over the tire in the garage and found the item stuck in the tire, there were actually two holes. I picked up a very large gauge framing or roofing staple in the middle of the rear tire tread.
I obviously need to replace the rear. I guess my question is should I also replace the front as well? The bike was assembled in March of 2014 so the tires are now a little over 7 years old even though they show zero wear or sidewall aging.
Opinions, advice, reasons?
Without reading any of the other replies, I would say most definitely, yes! Get rid of the 7 year old tire immediately. Not sure what other Forum members say, but I like to reply from 51 years of riding experience. Seven years is pushing the envelope for any bike tire's life span. Too stiff probably. When I bought the old GS750E, he had a 6 year old tire on the rear, and a 2 year old tire on the front. Even though the rear looked great, it went into the trash. Not risking my life for a $100 tire. Let's see what everyone else said.
(05-04-2021, 08:33 PM)peterbaron_imp Wrote: A tire can legally be repaired if one inspects it and follows DOT regulations. Simple.
Discount Tire will NOT repair any 7 year old tire. Liability is more the reason than just selling a tire. I cannot believe anyone would ride on a 7 year old bike tire unless you really could not afford a new one. Then, ask yourself, "How much is your life worth?"
Just to be sure why not test the repair with a little soap on the outside and look for bubbles or put bike on centre stand on a block and slide a deep enough tray under the wheel fill with water and check the whole tyre for leaks, not forgetting the valve of course.
I absolutely agree! Slight pressure differentials due to thermal Expansion and contractions, should easily be monitored on tire loss of air on short term .
Longer term results on a tubeless tire would yield different results in my opinion due to loss at the tire bead.
" Sounds like a bunch of HOT air talk to me...! Lol
2013 Cb 1100 "
Years ago, I mean a lot of years ago, I saw an ad in a magazine: "If you have a ten-dollar head, buy a ten-dollar helmet." That's been my mantra pretty much ever since. Extra points if you can identify the helmet mfr.
Bell
Wonder what inflation does to that number... like if you have a $125 head buy a $125 helmet? Lol
Edit
It's $76.11
Ferret, did you know that? I thought Bell, but had to Google it to verify.
I always loved the old Bell Star helmets back in the day.
No I knew it, I was in the motorcycle biz when they came up with that slogan.
Ref "ten dollar head...ten dollar helmet"...
Many years ago -- 1974, to be exact -- I had a rear tire blowout and dumped my CB750 on a Florida turnpike. While still in the air, and flying through my handlebars, the thought that actually went through my head was "I wish I had paid more than $10 for this helmet..." I had actually bought three helmets at $10 each during a clearance sale at S&K cycle, a Long Island cycle shop.
(05-10-2021, 12:20 PM)decarmine_imp Wrote: Ref "ten dollar head...ten dollar helmet"...
I am impressed one wore a motorcycle helmet in a 1974 Florida. From what can be reasoned this evening, it looks like all turned out quite well. Thumbs Up
  Current tire options for alloy wheels (tubeless tires) LucienLeFranc 46 2,095 07-25-2026, 12:59 AM
Last Post: Pete in PA
  Old 2015 rear tire: she needs new shoes valkyrie_rider_imp 15 1,090 02-09-2024, 03:03 PM
Last Post: valkyrie_rider_imp
  rear tire N.O.L.A. J Wag_imp 0 171 08-16-2014, 09:08 PM
Last Post: N.O.L.A. J Wag_imp
