Threads: 31
Likes Received: 117 in 50 posts
Likes Given: 64
My 2014 Std still has the original factory tires with a whopping 780 miles on them now. My back tire started feeling squishy today and I could hear a ticking at low speed. I had a guess as to why.
I made it home at a very slow speed (<25/mph). When I went over the tire in the garage and found the item stuck in the tire, there were actually two holes. I picked up a very large gauge framing or roofing staple in the middle of the rear tire tread.
I obviously need to replace the rear. I guess my question is should I also replace the front as well? The bike was assembled in March of 2014 so the tires are now a little over 7 years old even though they show zero wear or sidewall aging.
Opinions, advice, reasons?
Threads: 129
That stinks. Murphy’s Law says the newer the tire, the more apt it is to pick up a nail or screw. Actually, I’m sure there’s a scientific reason for it.
Anyway, if it were my bike, I’d have the rear tire repaired (if possible) from the inside, and I’d leave the front tire as is. If the rear can’t be repaired, I’d replace it but keep the front. Others will disagree, but the CB really isn’t a sporty or powerful enough bike to worry about a tire that’s seven years old. If you were to take the bike to the track and ride sidewall to sidewall at 10/10ths, my recommendation might be different.
Threads: 31
Likes Given: 64
(05-01-2021, 08:28 AM)LongRanger_imp Wrote: That stinks. Murphy’s Law says the newer the tire, the more apt it is to pick up a nail or screw. Actually, I’m sure there’s a scientific reason for it.
I don't know if I trust a repair on this. The staple was long and went in at a very steep angle, not just straight in. So on top of that there are two holes very close together.
Likes Given: 1,002
Threads: 41
Likes Given: 39
I would also agree with LR and Cormanus on this. An inside-installed patch/plug is perfectly safe, unless the 2 holes were so close that 2 separate patch/plugs couldn't be installed. Dunlop, Continental, and Michelin recommend no more than 10 years age, (but that may be their lawyer's recommendations). A tire stored indoors is not like one sitting outside in the sun and ozone.
But since the 2 nails are so close together. I'd see what a dealer says - they will likely just say replace it. In some cases, a single patch-plug could seal both, but an experienced professional should look at it.
Threads: 64
Likes Received: 6 in 2 posts
Likes Given: 7
At that age; replace both. Tires do not age well.
Likes Given: 140
I agree totally with Rboe.
No way I’d have tires that old on my bike or car.
Threads: 93
Likes Received: 9 in 4 posts
Likes Given: 6
It's a message from the Universe.
The Light Side has spoken, the force is strong with this one.
Threads: 31
Likes Given: 64
Well thanks for the input all. I know the back tire isn't as critical as the front, but since the way the staple went in, I feel like it probably isn't worth the risk and am going to replace the back tire for sure. Not so sure about the front though since it still looks like new. If there was any signs of cracking on the sidewalls I would just go all in and replace them both.
The OCD in me is going to go bonkers with mismatched tires though.
