Gear sprocket changes to improve acceleration
#41
How great is our bike of choice if we're now discussing ways to tame the monster a bit?
(06-26-2014, 02:44 AM)shdwghst457_imp Wrote: I would like my CB1100 to accelerate faster, allowing for some top end to be shaved off. I realize my cruising RPM will elevate with this, and because the bike is already really powerful I don't want to go to too extreme measures here. How can I make the bike pull harder? Should the front or rear sprocket be swapped, or both? Is one a more difficult endeavor than the other? Same question in regards to price.
to accelerate faster all you need to do is downshift. it is that simple.
Can't downshift from first!
For hard street battles I used to go -1 on the front and +3 on the rear. Might be too much on a long ride though. I voted both.
Hard core track tricks:
1. 520 chain conversion -1 & +3
2. remove wheel seals
3. remove chain slider
I'm backing off from this. I was already going 30 or so when I felt it start to kick out from under me; that's good enough!
Thanks for all the information, I ordered my 17 tooth front sprocket last night!
http://www.amazon.com/JT-Sprockets-JTF33...B000GTZ168
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,133 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,322 07-30-2024, 10:05 AM
  Acceleration and Deceleration Jolt / Harshness Mickey Dublin_imp 12 1,297 03-18-2024, 03:53 AM
Last Post: Mickey Dublin_imp
  Knocks on acceleration/deceleration Jurlie_imp 7 786 08-07-2023, 09:33 AM
Last Post: DutchRutter
  Front sprocket bolt cant be moved misterprofessionality 55 4,711 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,296 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,013 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,613 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,798 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 565 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
