About to order the '17 dual bending valve forks for my '14
#41
(01-22-2018, 11:24 AM)PowerDubs_imp Wrote: Gross.
Classic old bikes had silver forks...so then has mine. [Image: ef2181cb98a999bc0955f37c51deb7f0.png]
[Image: bdceb2f2fbf8e765fb0289962c33268e.jpg]
Your bike looks really nice PowerDubs! The '17 forks combined with the polished rims on your wheels is just right!
(01-17-2018, 04:06 PM)Ulvetanna_imp Wrote:
(01-17-2018, 01:24 PM)EmptySea_imp Wrote: Found your thread... This is pretty interesting. Did the mod change the amount of dive under braking? Also, and I may have missed this, what was the approximate cost of the replacement forks?
$438/side, $872 for the whole setup. Probably a few fasteners, fork oil, etcetera as well. Figure $1000.
As to the kits such as Racetech etc., the SDBV fork is a whole 'nother animal. A kit installed in the old forks will improve things but it's like a bandaid.
The new fork is a new, well-integrated system so well worth the money if one is really serious about a HUGE improvement.
But the kits can be had for about half that money and are pretty good.
Just seen this thread and looks like a bargain to me. I make it about the same price as the Andreani's cost me.
That said, in the UK the Duel Benders cost a lot more... but not as much as an original pair of Showa' would cost. About 2/3rds cheeper. They may be better but looks like they are cheeper to produce as well... win, win, win.
I'm not sure how the SDBVs feel but from reviews I've read and from what Power Dubs says, they sound like a good option for the road. The Andreani set up can still be a bit harsh on slow bumpy roads but at high speed and on track they are very, very good.
What do you have on your bike Ulvetanna?
Ulvetanna hasn’t logged in since February.
Doh! Didn't realise it was an old thread... noted.
Bumping this up for new people who might not realize there is an easy factory plug and play option to upgrade the suspension.
Here's a pic of my '17 fork caps showing some additional info at the top.
IMGUR link if you want a larger size pic.
[Image: 6777799273395572366fdcfd2d0ebf72.jpg]
[Image: d9a2ed8df30ca1c2a267373a5cd032bb.jpg]
They fit on the 2014 but NOT on the 2013 with ABS ( I tried but brakes are different)
(08-18-2020, 01:54 AM)Houtman_imp Wrote: They fit on the 2014 but NOT on the 2013 with ABS ( I tried but brakes are different)
Well, you could. The right fork slider are different for the 3-piston caliper on the 2013 ABS, but the internals should swap over easily enough. The fork sliders are just machined tubes, same inside diameter. The fork bushings are the same part numbers too.
Most of the magic happens inside the fork tube itself, in the damper rod valving. Plus different rate springs, and maybe lower friction fork seals. It may be even possible to swap just the damper rods and springs, and use the existing fork tube, if its I.D. is the same.
You are right but after finding out they did not "easily" fit on my 2013 ABS I just put them on my 2014 and that is a piece of cake to do.
  Valve clearance price Maturecheese_imp 44 3,935 03-05-2024, 07:11 AM
  Whoa- this CB1100 dropped a valve seat- PowerDubs_imp 13 1,299 10-23-2023, 11:43 AM
Last Post: 1973cb750
  Still lookin for that valve cover..... FLYTYM_imp 0 196 10-28-2020, 07:34 PM
Last Post: FLYTYM_imp
  Valve Extensions rbike_imp 4 442 09-16-2020, 01:48 AM
  still going to play with the front forks ohiorider_imp 5 546 08-13-2019, 09:31 AM
  CB1100 Dealer Order Availability In The US suhawk305 30 2,292 10-22-2018, 07:52 AM
Last Post: apex1_imp
  Thought I was done with the CB - trying again (forks) ohiorider_imp 80 5,741 09-30-2018, 11:20 AM
Last Post: LongRanger_imp
  Revised valve clearance check interval ohiorider_imp 28 1,928 02-23-2018, 08:38 PM
Last Post: jtopiso_imp
  Where do you order your OEM parts from? jdvalero_imp 9 611 11-07-2017, 04:38 AM
Last Post: rozbabbo1100_imp
  Be carefull what you order from Amazon jdvalero_imp 10 782 10-29-2017, 03:19 AM
Last Post: Chris Goldson_imp
