Deciding 37 vs 35 tooth rear sprocket on 2013, 19 on Front is correct
#41
(05-06-2017, 03:03 PM)IndianRider_imp Wrote: I installed the 19 and 37 combo and have a few hundred miles on the setup and I noticed I don't even think about the gearing/rpm while riding anymore so very happy with the smoothness without the abrupt engine braking on rolling off in any gear which is my preference ..
Looking forward to the 19 /35 combo setup from rbike
Hi IndianRider, I'm interested in performing your same sprocket mod. I was wondering, now some time later, your long term impression of the change. Are you happy with it? Did it improve your MPG? Where did you source your sprockets?
Thanks!!
Jeeves (New CB1100 Owner!)
Sorry I didn’t see this earlier. I have about 3500 miles on the sprocket setup and am loving it. I don’t even think of trying the 35 rear sprocket. I don’t ever check the mpg and you can look at my previous posts for where I sourced the sprockets.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,524 08-16-2025, 05:01 PM
Last Post: bflint
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,058 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,262 07-30-2024, 10:05 AM
  Rear only tire on the front? mattmcuomo@yahoo.com 5 596 10-09-2023, 06:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,538 03-13-2023, 12:18 PM
  What is the Correct Chain Size for a 2014 Model? chync_imp 12 1,156 02-28-2023, 01:16 AM
Last Post: Maturecheese_imp
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,224 11-29-2022, 07:49 AM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,425 06-03-2022, 01:16 PM
  VIBRATION - deciding too much; and living with it. JustPassinThru_imp 132 10,786 05-31-2022, 07:47 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 991 01-03-2022, 08:30 AM
