Seat lock stuck problem
#41
Okay Guys, my bad . . . THE KEY WILL TURN TO THE 5 O'CLOCK POSITION FINE, BUT THE HELMET LATCH SIMPLY WILL NOT PULL DOWN TO UNLATCH THE SEAT. The key also will go into the 1 o'clock position too to relock the helmet holder latch. In other words, the keyed lock seems fine, only the piggybacked "seat latch" mechanism is stuck closed. I just looked at it again and drilling out the two break off screws is probably my only option at this point. I hate to do that, but I can't see any other way. All the seat bashing and cursing ain't getting it done! Should I attempt this myself or just take it to the dealer under warranty or call a locksmith?
if it's under warranty still, take it to the dealer for sure!
I'd take it to the dealer before I messed around with drilling things. Just to be clear, though, you don't pull on the helmet hook to open the seat...the seat latch pull is behind and slightly above the helmet hook.
Good advice ferret. It IS still under warranty with 6 months to go. Luckily, I have no need to take the seat off for any other reason in the foreseeable future with a semi-permanent BT hookup already in place. The DMV registration is the only valuable thing under there, but hopefully won't need that in the interim either. I was hoping to mount a grab rail accessory I bought from a fellow member here recently, but I guess that may have to wait now. :-(
The bike is still under warranty? After all this?! My goodness.
(11-23-2016, 08:05 AM)dsinned_imp Wrote: Okay Guys, my bad . . . THE KEY WILL TURN TO THE 5 O'CLOCK POSITION FINE, BUT THE HELMET LATCH SIMPLY WILL NOT PULL DOWN TO UNLATCH THE SEAT. The key also will go into the 1 o'clock position too to relock the helmet holder latch. In other words, the keyed lock seems fine, only the piggybacked "seat latch" mechanism is stuck closed. I just looked at it again and drilling out the two break off screws is probably my only option at this point. I hate to do that, but I can't see any other way. All the seat bashing and cursing ain't getting it done! Should I attempt this myself or just take it to the dealer under warranty or call a locksmith?
MY WORD! If you had followed the advice given earlier. Oh, well, this thread has kept our minds occupied--err, boggled.
From the owners manual.
(11-23-2016, 09:25 AM)Sam Mac_imp Wrote: From the owners manual.
When I first bought my CB1100 last year, I had to ask the shop how to remove the seat so I could get the owners manual out to see how to remove the seat. I got double looks from the tech but he showed me how to remove the seat--laughing sheepishly.
Lol well lets not be too harsh. The owners manual was under the seat so he couldn't read it. I like this to trying to put bike in gear with sidestand down or trying to start bike with emergency kill switch on. Things many of us have done. It is a complicated and stupid system.
Hey when I bought my CB the salesman had to get the tech to show him how to open it. I took a pic for you looking at it from the rear of the bike. Hope this helps.
  CB1100 Idle speed instability problem ericlo69_imp 1,436 123,172 Yesterday, 12:54 PM
  idle problem update 1973cb750 37 2,172 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Stuck Gear Linkage Nut — Can’t Loosen Without Twisting the Rod Narciso 5 1,691 10-10-2025, 09:24 AM
  "Seat Lock" cable unseated. 17-CB-002 10 1,059 08-27-2025, 08:19 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,365 07-30-2024, 10:05 AM
  O ring chain problem Mixagon_imp 7 685 10-17-2023, 07:28 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,169 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
  May have a problem the Ferret 12 863 01-20-2023, 04:53 PM
Last Post: max
   2017 EX Headlight Dimmer Switch problem? sleeper_imp 24 2,001 10-08-2022, 12:27 PM
  Fast Idle Problem Solved Nachodaddy 17 1,581 10-08-2022, 09:18 AM
