K&N Oil Filters BEWARE!!!
#41
Why K&N has not been sued beyond severe pain is beyond me. But obviously the product is junk and one should not use it.
(10-23-2016, 07:12 AM)Cormanus_imp Wrote: Bump!
Five days ago Pterodactyl's K&N oil filter failed in exactly this way. Luckily no great harm was done. His exhaust and rear tyre got a good coating of oil and he was lucky to have been on a good highway.
I'll remove my first K&N filter at the first opportunity.
Good to know both he and the CB are OK. Riding is risky enough without worrying about oil filter failures. Sad
Glad to hear that Tony suffered no physical harm but I'm puzzled that his secret Dactyl blend motor oil did not miraculously stop this incident before it happened.
I have a K&N in the back seat of my car waiting to go on the CB as part of its 600-mile. I'll likely stop by a Honda shop and pick up an OEM filter after reading this.
I have an oil change coming up and after reading this, I'm definantly going to use something other than the K&N filters I have been using the last 12000 miles! My mind would never be at ease. Geez. The thought of it giving way when I need rear wheel traction makes my skin crawl.
Plain and simple...I use OEM everything when it comes to the mechanical components of my vehicles. The last thing Honda or any other manufacturer wants is to pay out for warranty work due to faulty parts etc...if its's good enough for Japanese engineers it's good enough for a dummy like me. Dodgy
"Glad to hear that Tony suffered no physical harm but I'm puzzled that his secret Dactyl blend motor oil did not miraculously stop this incident before it happened."
Whilst Cormanus rode to away to source a replacement filter along the road out of Gundagai Hubris Galactic Dactyl technical annalists established the superior friction modifying properties of the latest blend, also found on turn #4 at Phillip Island.
If I had not seen it i would not have believed it.
Regards
(10-25-2016, 09:25 PM)noroomtomove_imp Wrote: "Glad to hear that Tony suffered no physical harm but I'm puzzled that his secret Dactyl blend motor oil did not miraculously stop this incident before it happened."
Regards
ROFLROFLROFLROFL
Pulled my K&N filter yesterday as it had a slow leak and I was down a pint. I tried to use the nut on top to remove the filter but it just spun. That's a sign, I think. Anyhow, to answer my own question from a different thread, you will lose about a quarter cup of oil if you remove the filter without first draining the oil. So use a catch pan but have no fear of a big mess.
Regards
ROFLROFLROFLROFL
"Spun" how exactly?
Did the stamped nut round-over in your wrench, or did the spot welds that hold the stamped nut to the canister break loose?
If it was leaking, I would suspect the latter to be the case. Of the two unused K&N filters I still have, one has definite air gaps between the stamped nut and the canister...really makes me suspect the integrity of the spot welds.
Regards
ROFLROFLROFLROFL
"Spun" how exactly?
"Spun" how exactly?
If it was leaking, I would suspect the latter to be the case. Of the two unused K&N filters I still have, one has definite air gaps between the stamped nut and the canister...really makes me suspect the integrity of the spot welds. Actually, it just turned. As if the nut and it's flat plate were pressed through the can and attached like a rivet. I will go take a better look. Might cut it in half if I can find my hacksaw.
  Counterfeit Oil Filters 2017EX_imp 111 8,939 03-24-2023, 01:31 PM
Last Post: 808_rider_imp
  Battery replacement - Beware aftermarket pekingduck 45 2,852 02-21-2020, 10:21 PM
  Air Filters BIGGREEK_imp 20 1,416 02-18-2018, 10:50 PM
Last Post: jimgl3_imp
  K&N oil filters .. known issue..FYI the Ferret 13 832 11-24-2017, 01:32 AM
  K&N Filters: use grease when installing Ulvetanna_imp 4 479 06-26-2016, 01:48 PM
Last Post: Ulvetanna_imp
  Out of gas - Beware estimated miles remaining! EarsOnWheels_imp 33 1,946 06-03-2016, 08:39 AM
Last Post: lol_imp
  If you change your own plugs, beware! sanoke_imp 2 279 03-22-2014, 10:53 AM
