Some valve adjustment tips and tricks.
#41
(12-22-2020, 03:15 AM)max_imp Wrote: Two good video's with very detailed info about valve checks and adjustments.
Valve clearance check;
https://www.youtube.com/watch?v=1ipQ1XI1brU
And valve adjustment;
https://www.youtube.com/watch?v=tbgG3uQgECc
Hope this helps.
Hmm, interesting.
Hope the characters are still/will remain all healthy.
After all this, I am well resolved to simply run this motor until it locks up. If and when it ever locks up, I'll tear into it, but not before.
Smile
It won't lock up. Just keep the oil changed.
It may just get hard to start, run worse, eventually get noisy, blow smoke, etc.
(12-22-2020, 11:44 PM)jimgl3_imp Wrote: After all this, I am well resolved to simply run this motor until it locks up. If and when it ever locks up, I'll tear into it, but not before.
lol - better put a clause in the Will to get someone to run the beast until the motor locks up.
I wouldn't take the risk, would you not at least measure/have them measured? I decided to check the valves on my other bike with 31K miles on it and the service book showed two previous dealer valve services. I believe the first but totally disbelieve the second. 6 were out of spec (not just at the extremes of spec) and one inlet valve was totally closed up. If I had left it a new head would of been the order of the day and it would of been very expensive.
(10-17-2020, 04:00 AM)max_imp Wrote: From the Honda service manual;
Made mine from 1 mm. copper, worked fine; find the slot inside the tensioner, wind clockwise till the stop and return until the wider part of the tool lines up with the four outer slots and push the tool in those slots to lock the unit.
What Honda service manual? I have both Common Service Manual an 2013-2014 CB1100 Service Manual, but can't find your cool diagram.
Must be an old diagram which is why i posted the dimensions, do you like it?
They now have a flash new tool which you could order, it's a lot bigger to work with and may fall out of the tensioner for that reason, up to you but i liked this way so i thought i would add it to Wyliejoe's awesome collection and you only need it when you remove the camshafts as discussed.Smile
Well reasoned videos. Thanks for sharing.
Thanks for feedback Mr Max ... I made the tool from your pic. Ok Mr LakeWylieJoe .... I read your guidelines, printed out the Service Manual pages and reordered them per your list, ordered and received all the parts, and prepped the garage. Just re-reviewing service manual pages and your notes, then will start doing my 2014 CB1100DX this week Smile
Good luck Bill and keep us updated !
  Valve Adjustment Shims dave 13 904 07-28-2026, 12:49 PM
Last Post: MagnaRider
  Valve Adjustment and Camshaft Removal dave 5 696 03-21-2026, 04:49 PM
  Valve Adjustment dave 6 926 08-29-2025, 10:46 AM
  Valve Cover Baffle lining ? bflint 6 1,045 07-26-2025, 11:27 AM
Last Post: bflint
  Valve Adjustment Intervals CBRider_imp 32 3,456 04-21-2025, 02:24 PM
Last Post: Jurlie_imp
  Rear Brake Pedal Adjustment Gone in 60 12 1,282 04-04-2024, 08:18 AM
  New members tips max 54 5,150 10-29-2023, 12:11 AM
  Valve Adjustment Tolerances - How Far Do You Go? dave 14 1,747 10-18-2023, 09:28 PM
Last Post: The Gecko_imp
  Observed Valve Clearance Cormanus 16 1,661 03-06-2023, 09:03 AM
Last Post: Tejas_imp
  The OBSERVED Valve Clearance thread Pterodactyl_imp 162 15,406 12-27-2022, 08:35 AM
