How To :19 tooth front, and now, a 37 tooth rear sprocket on 2013
#41
Gentlemen,
Here are a couple photos of the 7th Gear Design steel 37 tooth sprocket on my 2013 CB1100. Great looking piece. The black sprocket is the stock 39 tooth unit.
Chip
[url=http://s288.photobucket.com/user/chipbeck/media/July%2024%202015%20I-Phone%20photos_5096.jpg.html][Image: 3278f9a4650872d27e06559469e27244.jpg]
[url=http://s288.photobucket.com/user/chipbeck/media/July%2024%202015%20I-Phone%20photos_5056.jpg.html][Image: 93dfcde5b83709a954d250435cf77b05.jpg]
This is similar to my question on my follow on 35T thread.
Question for any that may know, I was planning on breaking the 530 chain, shorten, and add a new master link, but the stock 530 appears to "works" with the 19/37 combo. "Works" - from the pics, it appears the rear axle needs to be moved aft 3/8" to 1/2" for proper chain tension. How much is then available for future use as the chain stretches?
Is there an equivalent new chain available for my 19/35 combo that would eliminate the need to break the chain - 520, 510?
Chip, how long have you had your sprockets? I assume they are steel & no Rust is visible.
Were they zinc plated?
(11-11-2015, 06:24 AM)rbike_imp Wrote: This is similar to my question on my follow on 35T thread.
RBike,
I think I've had that sprocket on for about a year. I don't know for sure but I thought it was stainless steel and it's clear coated as well but obviously clear coat would come off the teeth immediately. There is not a spec of rust on them. There is no master link on a CB11 chain. It is an endless chain.
Chip
Thanks Chip, I recall the installed 530 chain is one piece without a master, so I am looking for another 530 chain that is still a continuous chain, but shorter vs. cutting and adding a master.
There is a local MC mod/repair facility that has the proper tools (like at http://www.didchain.com/chainTools.html - vs. me buying it) and experience to shorten the chain, but I am also trying to find a shorter chain if possible. I'm just a little OCD regarding doing it properly the first time. I learned early in life that being ---- is more costly in the long run.
7th Gear Design is manufacturing mine also. It would be great if he is using stainless.
Does anyone know if 7th Gear Designs is still around. I have failed to make any connection with the company for two weeks now. Emails and voice mail messages are never returned. I would really like to have a set of sprockets but am about to give up on it.
(11-24-2015, 10:56 PM)redbirds_imp Wrote: Does anyone know if 7th Gear Designs is still around. I have failed to make any connection with the company for two weeks now. Emails and voice mail messages are never returned. I would really like to have a set of sprockets but am about to give up on it.
Redbirds, you asked this question on the thread (http://cb1100forum.com/forum/showthread....04&page=2) I specifically created to address the sprocket issue to a new (higher) level. Mine being the ultimate possibility of what is possible. 19T front & 35T rear. In case you did not read my reply to your question on that other thread, I will repeat it here.
"Redbirds, Copied down from my earlier post:I am using 7th Gear's contact info on his website. It still works, but he is apparently very busy and it takes time before he is able to reply. I'm still waiting for his reply email to start production on the sprockets.
Update 11/20/15: He has my order and $ to manufacture my F & R sprockets. I do not have an update on his production or shipment yet, but I expect them soon. Send an email and phone call and wait is all you can do right now."
Update 11/25/15: I am just now getting emails that he read my emails from weeks ago, one of his replies is that he is manufacturing my sprockets this week/next week and they should ship out in the next ?7 days or so, but I am not holding my breath, ... They will show up when they show up. From what someone else on this forum mentioned, he has a primary vocation, he is moving, ... be patient. You are experiencing the frustration, I initially had, but observe patience and he will eventually get in touch when things settle down. I initially contacted 7GD back in the late August / early September time frame. Good things come to all that wait - even if at times it seems frustrating.
My goal is to test/prove my idea/design #s that Fukunaga and his Honda design team had it wrong. They could have just added a 6th gear or designed the 5gear better from the start or as a mod, ... ([url=http://world.honda.com/CB1100/engineer-talk/episode3/).]http://world.honda.com/CB1100/engineer-talk/episode3/).
<= Great article. I am truly overwhelmed at this flaw in otherwise perfection. Ideally, they could have manufactured 2 versions, just like the ex, dx, abs, ... One would be high revving and the other low for the cruising customer base. My gut feel, is the later would have higher sales.
When I get done with everything, I will post a summary of all of my mods (w pictures) for all to view and self evaluate if it makes sense for them just as I have from the wonderful volunteers before me on this forum that I am thankful for.
Happy thanksgiving to all.
I guess I made the tie in to food, burgers, and finally football!
LOL
When I first joined, I wondered how anyone could get to thousands of posts, but I am quickly learning. Double to Triple digits / month adds up fast. I don't think I could keep that rate once my farkle period is over though. I know, it never ends.
I will be patient and wait for a reply.
And a Happy Thanksgiving to you and all on the forum.
(11-25-2015, 12:21 AM)redbirds_imp Wrote: I will be patient and wait for a reply.
Likewise.
FYI, I updated my 35vs37 thread post regarding the sprocket finish(s) http://cb1100forum.com/forum/showthread....#pid112855
Such great info on this forum.
I feel the same thing as Chip in my 13. Now I see a solution, many thanks to all.
It's a pleasure to learn all the great information here. Thanks to you all. I ordered 19/37 from PBI Sprockets and the package will arrive Taiwan soon. It's very hard to find a 19 sprocket in Taiwan or Japan. And can't even find a similar discussion anywhere. Should thanks to google as well for guiding me here. Thanks.
  Rear indicator (Turn signal) relocation bracket 2013 model AndyBeeMD 15 1,529 08-16-2025, 05:01 PM
Last Post: bflint
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,076 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,271 07-30-2024, 10:05 AM
  Rear only tire on the front? mattmcuomo@yahoo.com 5 600 10-09-2023, 06:05 AM
  Front sprocket bolt cant be moved misterprofessionality 55 4,575 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,247 11-29-2022, 07:49 AM
  How to remove 2013 Rear ABS/Speed sensor danieljrmurray_imp 16 1,429 06-03-2022, 01:16 PM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 996 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,564 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,756 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
