#41
I can almost bet it is the IACV. And your dealer tech should be able to troubleshoot it fairly easily. If he has a service manual, he needs to read it.
where do i find that part on the exploded view?
http://www.bike-parts-honda.com/moto-hon...15629.html
edit
I see parts 6 and 8 described as AICV.
6 is a joint and 8 is a plate...
[Image: 0d6696e7e279b54544900433db617846.png]
You said the dealer has to read it, what do you mean? Via ECU diagnostics? Or is this a pure mechanical part?
http://www.bike-parts-honda.com/pieces-h...S+ABS.html
Item 4. Its called a motor assembly on the parts fiche
If they think its the TPS, the book covers troubleshooting on that too. However, you can't get it separately.
Sorry to ask again. But where do i find the tps?
(04-29-2016, 08:50 AM)Riko_imp Wrote: Sorry to ask again. But where do i find the tps?
You have to buy the entire Throttle Body assm. You really don't want to have to do that. But, to answer your question. Look at the pic and notice the arrow indicating forward. On the left side of the Throttle body ( or on the bottom right of the pic), you can see it.
If you look at the left side of your bike, just in front of the air box cover, you can see it. Has 2 screws and an electrical connector on it. The TPS is shapped just like in the parts diagram.
Just to add to the discussion. We had a TPS thread a long while back. A member said that even though the TPS is not avail from Honda, the voltage specs for it match a TPS for some car. He said it could be used. Using the min/max values in the book, it could then be adjusted to match.
Disclaimer: I have never done it as mine is ok. Do some research first.
TPS failures usually set fault codes. If they can be faulty and not cause a code to be set, well, someone else will have to address that.
Thx a lot man!
Is there any way to clean the AICV or perhaps disconnect the plug and reconnect? Would that help?
I will have a look later, but I suspect the AICV is on the right hand side. If I can reach or see it is another matter.
According to the service manual, you'll need to remove the fuel tank to get at the 4P connector. Is the bike still under warranty? If so, I would suggest letting the dealer solve this problem.
+1 on what Curly said.
To answer your question though, sure you could reseat the connector. Pins oxidize. You'd be surprised how many problems in electronic systems are fixed by simple connector or component reseats.
The manual even shows a test where you remove the IACV and watch it while turning the ignition key on. Even some resistance checks. I would not do any of that though if it is under warranty. And if not, you need to get a service manual, a DVOM and some electrical/electronics knowledge would help too.
(04-29-2016, 07:56 PM)curlyjoe_imp Wrote: According to the service manual, you'll need to remove the fuel tank to get at the 4P connector. Is the bike still under warranty? If so, I would suggest letting the dealer solve this problem.
yeah indeed, I got warranty till 9th of December. (obligatory 1 year warranty for second hand vehicles)
Whats bothering me about all of this, is the fact that the Taiwanese EX owners who have the same issue, don't seem to have seen their issue resolved.
I read the comments on the Taiwanese cb1100 facebook group (lots of pics! Thumbs Up) and use google translate, but as far as I can trust the translation, the results aren't very hopefull.
Same on the French board.
There I saw a few members mailed to the European office: cco@honda-eu.com
And so I mailed them as well describing the problem, luckely for me the European main office, wich happens to be in Belgium Thumbs Up
And so far nobody had received any answer.
Yesterday I talked to a guy that admired my bike and told him about my problem.
Long story short, he said its not abnormal they do not reply.
They could be waiting to reply until they got a bunch of complaints...
Ow well, whatever the case is, I'll visit my dealer.
Problem is, I can only go Friday, they have a death in the family so the shop is closed the next few days.
I do however have my mechanic who lives very close to me and he is a freak about air cooled Honda's and does custom jobs and in his shop he has always a few of those bikes he works on.
He also does maintenance service for all other bikes and scooters.
If my official dealer does not find the solution, I trust my mechanic will.
(04-30-2016, 01:09 AM)Lord Popgun_imp Wrote: +1 on what Curly said.
this sounds logical, however, when I look at the way the bike handles and the conditions the problem occurs, I suspect its not a matter of a bad connection.
Because, the bike rides fine in city condition (lots of stop and go) but after 15 -20 min, the starts to drop rpm's....
And the bike is fixed as soon as I push the kill switch, than I'm good to go for another 15 min in city traffic without issues.
I think with a bad connection the bike would drop rpms from the start and not always after a certain amount of time.
I think, but I could as well reseat the connector I guess.
1 thing is for sure, I need to get myself a service manual! I'll be looking into that this evening I guess.
I've seen something on ebay where you pay 21 dollars for a PDF, with only 1 left Dodgy
And I am not sure if that one is also for a DLX model.
Any suggestions are welcome Smile
May be a faulty kill switch? Since touching that seams to change things, I would inspect it as well.
  idle problem update 1973cb750 37 2,039 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 845 10-22-2025, 02:11 PM
  New speed meter replacement ACE_IRA_imp 3 518 02-13-2025, 06:25 AM
  Idle a little rough and miss fire when revved johnnyH_imp 3 408 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,206 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 945 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 632 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,530 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,038 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 4,579 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
