That is sort of what I am doing.
What I have started is
Name, country, original post date as far as I can tell, and what was done to cure it
Example (3 of first 11) from first 15 page thread
Jeff Hark USA 1/2016 IACV replaced
Glackie Canada 9/2016 TPS reset
Tory Thailand 10/2016 ECU refresh
Notice, 3 countries 3 different cures
I did not note year, model of bike most were 2014 EX's I think but I can gather that info if posted
Headed to page 1 of this thread now will report entire results from both threads when completed.
I can help out too. As pdedse suggested, I can put together a google spreadsheet and share it with everyone. It would be ideal to extract as much info from the 2 threads as possible. It's easy to add columns to a spreadsheet.
Have all the info jotted down. Right now I'm going to type it into a Word thingy and post that, and curlyjoe, if you want to make it into some kind of spread sheet thingy all the better.
I'm in!
Its good to have a track record of the issue!
I'll share the link on the various international facebook groups and other national boards I'm a member (French, German, UK)
Idle issues compilation
Name country model mo/ year posted issue cure
Ericlo69 Taiwan 2014EX 3/2016 High Idle throttle Valve Assy replaced
Johnf514 USA 6/2016 High Idle IACV replaced/ecu reset
Glackie Canada 2014 Std 9/2016 TPS reset
Dave USA 2014 DLX 9/2015 high/low idle/stalling 12/16 Battery replaced, 8/16 self cured, 1/17 disconnect EOT, 3/17 high speed runs
Tory Thailand 10/2016 ECU upgrade
BeardyWeirdy UK 2014EX 11/2016 ECU software upgrade
Wisedrum Germany 11/2016 High Idle Disconnected Battery
Rolls USA 12/2016 High Idle High speed runs/track day
736cc USA 2013 std 12/2016 Replaced battery
Macenthor USA 1/2017
TK Lee S Korea 10/2015
LARider USA 2014 std 4/2016 low idle Self Cured/bad Gas
MotoGeezer USA 2014 DLX 4/2016 low idle happened once/self cured
Riko Belgium 2014 EX 4/2016 low idle Throttle body assy replaced
Scooticus Malaysia 5/2016 Loosened throttle free play
Dinap1981 Italy 12/2016
Kmoney Canada 9/2016 high idle unplugged EOT
Magnus USA 3/2017
Mechanix USA 3/2017 self cure
RandyB USA 2013 std self cure/bad gas
Hatred66 USA 2014 std 3/2017 High Speed run
Sandhog USA 2013 ABS 3/2017 low idle EOT sensor replaced
Dsan1964 USA 7/2017
MM300 USA 2014 DLX 7/2017 TPS reset
Pdese USA 2014 Std 7/2017 high idle
*** New different issue
Rustyski USA 2014 STD 7/2017 Died at 70 mph
additional notes
8/2016 Beardy said new mapping available soon that stepper motor shutting down too quickly
according to Daves research the same IAVC is used on over 100 different Honda models from 500cc to 1100cc dating back to 2007
3rd hand info
Was noted in Holland France and Netherlands good luck was had with replacing IAVC
Someone in Asia I believe mentioned a throttle body cleaning cured the problem on a fellows there
I noticed when looking where everyone was from that the vast majority of USA owners reporting issues were from California (weird huh?)
Finally
Beardy reported 2017s have a different IAVC
Good job, Ferret
Well it was all spaced nicely in columns when I typed it into Word. Copied and pasted here, it all slammed together lol.
Thanks to Ferret for digging up this data.
Here's the[url=https://docs.google.com/spreadsheets/d/1qd6ncVq510VJrFiv7-MGQ5FHNMdHeLxpyQO14I7-UpE/edit?usp=sharing] link to the spreadsheet
Anyone with the link can edit the spreadsheet.
There's some missing data so perhaps the forum members can add missing data to their line in the sheet.
Thanks curlyjoe!
Ferret: Thank you so much for doing this! All of us with idle issues thank you. Curlyjoe, thank you for creating the spreadsheet - I will edit it right after I complete this post.
I am willing to bet that some of the cures, such as bad gas, TPS reset, and replacing the battery are not permanent. My issue comes and goes as it pleases. Is there a way we can include on the spread sheet if the "cure" was permanent or not?
I did not see the post from Beardy about the different part number on the IACV - this is very interesting! The throttle body assemblies are the same part number for both years, so this means the new IACV can be installed in the earlier models. However, the PGM-FI Units have different part numbers, so I am not sure if the different part number IACV would work or not. However, I would really like to know why Honda changed the part number for the IACV. I am the one who posted that the CB1100 IACV part number is used on many different Honda motorcycles - why suddenly change it?
Thanks again to Ferret and Curlyjoe for help resolving this annoying issue. This is exactly why I love this forum - people are so willing to help.
  idle problem update 1973cb750 37 2,177 05-12-2026, 08:38 PM
Last Post: rdprdp01
  Public Service Announcement - Speed Sensor Clip Gone in 60 7 919 10-22-2025, 02:11 PM
  Idle a little rough and miss fire when revved johnnyH_imp 3 442 09-15-2024, 12:16 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,367 07-30-2024, 10:05 AM
  another idle thread Tom_imp 11 1,068 11-20-2023, 01:30 PM
  O ring chain problem Mixagon_imp 7 691 10-17-2023, 07:28 AM
  TPS Sourcing because of High Idle Obi-wan Kenobi_imp 38 2,926 09-14-2023, 10:08 PM
  Honda CB1100 Rough Idle Solution dickie1951_imp 56 4,584 09-06-2023, 01:36 AM
  About the problem of high idling. (2014 cb1100ex) DDUMZI_imp 62 5,193 08-02-2023, 05:38 PM
Last Post: DDUMZI_imp
