Phone mounting issues
widude Offline
Wisconsin
Threads: 9
Likes Received: 3 in 1 posts
Likes Given: 1
RE: Phone mounting issues
#31
Just looking over these ideas about phone mounting, doing more medium length errands on the bike. My main reason is navigation, not staring at the phone, but reminders at times.
I try to just memorize turns enough to get me going a while, not always easy. I’m looking over that calimotor app some too.
06-09-2021, 09:52 PM
#32
Sourdough: In terms of navigation, a Cardo Freecom or similar Bluetooth audio solution will allow Google Maps to verbally queue you of your turns while your phone is in your pocket. Something worth reviewing.
06-09-2021, 11:24 PM
Whoops Offline
Utah, USA
Threads: 30
Likes Received: 112 in 48 posts
Likes Given: 64
#33
(02-14-2021, 04:16 AM)E11even_Hunnit_imp Wrote: As explained on the other thread, later iPhone cameras will literally take a sh*t with the RAM X mount, due to the vibrations. This is not the case for every smartphone out there though- I ran a 6S Plus over the course of 4+ years on different bike/stem mount setups, camera didn't even flinch.
You can try to get some foam and make some sort of dampening pad to help ease the vibrations if you want, but as someone who has been to the Apple store for repairs/replacements more than 5 times over the course of 6 months, I don't recommend you try your luck, at least not without having Apple care or some other form of warranty.
The RAM X cradle works wonders, provided you have all 4 rubber pads AND use your corner "net" restrain. Why it's too much to handle for the newer iPhones is beyond me
Is it the bike that produces vibrations that are too intense? or is it that the phone/camera design is flawed from the go? Who knows
You have been warned
The problem with the vibration is that phone with image stabilization have a gyroscope in the OIS (optical image stabilization) unit. It isn’t digital stabilization but rather mechanical. Constant vibration of that gyroscope causes it to fail much sooner than normal. Failure of the OIS will cause your camera to be unable to focus.
The phone can also be affected by the vibration causing ribbon cables to become disconnected which can cause display failure issues, antenna reception problems, etc. Most of the problems can be repaired either with a new OIS unit or reconnection of any disconnected cables.
06-10-2021, 12:55 PM
MrBob_imp Offline
Threads: 6
#34
(02-09-2021, 10:58 AM)ride4now_imp Wrote: Hey guys, I’d like to use Ram Mounts X-Bracket on my bikes to hold my IPhone11. However, I’ve heard some negative reports that the phone can’t handle the vibration. Has anyone had an issue with their phone on their bikes? I probably wouldn’t use it on my KLR (if I’m off-road) but seem to think it would be ok on my CB and even my Harley. Any thoughts?
i mounted my iPhone 8+ on a Ram X on a different bike and it killed the auto-focus after just a few rides. To my amazement, Apple replaced the camera under warranty.
06-14-2021, 08:27 AM
nsrrider_imp Offline
Threads: 4
#35
I'm a really slow learner.....I've killed 3 different I-Phones (10 and 11) camera sensors using a variety of phone mounts....my friends android phones don't seem bothered--but their cameras aren't as good IMO
09-28-2021, 12:51 AM
#36
(09-28-2021, 12:51 AM)nsrrider_imp Wrote: I'm a really slow learner.....I've killed 3 different I-Phones (10 and 11) camera sensors using a variety of phone mounts....my friends android phones don't seem bothered--but their cameras aren't as good IMO
... iPhone/iPad folks seem to always ooo 'n' awe over Samsung Galaxy S android camera quality. (e.g. S8 and later, especially S10 and above).
I think: Wait, you use iPhone?
09-28-2021, 01:46 AM
whizzle_dizzler_imp Offline
Threads: 3
#37
Haven't read through all the posts, but my experience - For over a year, 90% of my 40 minute (each way) commute to work on my CB1100 with an Ram X-grip mounted with the u-bolt attachment just to the right of the right side handlebar riser. I also have an iPhone 11 Pro with a Unicorn Beetle case. I have not had any issues with my phone. That being said, the Unicorn Beetle case is pretty good about damping the force from drops. If you're worried about the phone, I'd just get a decent case with good shock absorbing features.
09-29-2021, 04:24 AM
Threads: 346
Likes Given: 963
#38
I can’t remember where, but I’m sure I recently read that phone companies, and maybe Apple in particular, were warning about the dangers of certain types of vibrations for the small mechanical parts of their cameras.
09-29-2021, 05:42 AM
  Phone or Sat Nav? What mount ? Quad lock or...... Davidjill_imp 18 1,282 07-28-2024, 08:49 AM
Last Post: SportsterDoc
  Honda Top box mounting Lord Popgun 8 771 06-22-2023, 12:09 PM
  3D printed strap adapters for the CB1100 mounting pegs LayerCake_imp 33 2,131 07-10-2022, 12:04 AM
Last Post: 1973cb750
  Mounting a garage door remote Gone in 60 21 1,265 06-24-2021, 01:40 AM
   CB Custom - Speedo/Tach Wiring Issues CafeBandit_imp 38 2,533 10-13-2020, 12:53 AM
Last Post: Ninemeister_imp
  usb/cell phone charger setups.. ? el duque_imp 17 1,225 04-22-2019, 07:27 PM
  Denali sound bomb mounting location? Jeeves_imp 3 426 10-08-2018, 08:30 AM
  Mounting a GoPro on the CB1100. Some ideas. Pterodactyl_imp 42 2,972 08-05-2018, 04:33 AM
Last Post: zbillster_imp
  My phone as GPS didn't pan out el duque_imp 21 1,127 05-07-2018, 01:54 PM
Last Post: Offroad
  Vario Footpeg replacement mounting bolts Ojiisan_imp 2 313 04-19-2018, 03:07 AM
Last Post: Ojiisan_imp
