Break in oil?
#31
The owner's manual for my wife's 1947 Chevy states "The crankcase of the engine in this vehicle as received by you is filled with a light body 'breaking-in" oil. Use this oil only during the breaking-in schedule shown below. It should not be used after the breaking-in schedule"
Clearly, break in oil has been around for quite awhile and continues to find applications.
(01-25-2014, 02:22 AM)Randy B_imp Wrote: I could go on, but suffice to say it's no myth.
"Years ago" oil had MUCH higher levels of [url=http://en.wikipedia.org/wiki/Zinc_dithiophosphate]ZDDP than it does now due to tighter emissions regulations. With the proliferation of roller valve trains the need for it has been reduced and this had allowed the government to pass more stringent regulations in regards to ZDDP and thus "break in oil" was born. It is ONLY to be used for short periods to break in an engine, not full oil change intervals UNLESS the engine is of a flat tappet design with no catalyst. ZDDP destroys the catalyst in a much shorter time frame than it would normally wear out.
Hahaha OK, I give! Worship I'd never seen it before anywhere.
Don't feel bad, I've never seen that either.
  What did I break? Cbcarolina_imp 4 398 12-03-2023, 10:44 PM
  Engine break out tips and tricks ACE_IRA_imp 7 497 01-29-2019, 12:30 PM
  Engine break in test - recommended vs aggressive chync_imp 7 643 11-23-2018, 06:21 AM
  RANGE and BREAK IN Streetshark07_imp 9 798 11-15-2018, 03:02 PM
Last Post: Streetshark07_imp
  Break pads.....just in time....so eaaaaaasy!!!!!! jdvalero_imp 16 1,024 08-12-2018, 09:32 AM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 700 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
  New Engine Break In zippooriginal_imp 3 331 07-12-2016, 01:47 PM
Last Post: riceburner_imp
  Oil Consumption During Break-in? Gumby 1100_imp 31 1,992 08-29-2014, 06:33 PM
Last Post: Stary Motocyklista_imp
