Gear sprocket changes to improve acceleration
#31
Great photo, Randy. How are you healing? How's the bike?
There is a pic of the header wrap.
[Image: d26ea31daf8cb8c9d762326ffd640754.jpg]
(06-29-2014, 12:24 AM)U.S.Cavalryman_imp Wrote: There is a pic of the header wrap.
This is the first CB11 I've seen with wrapped headers, it looks pretty cool!! IMO, it would look more homogenous with short black fenders and some lower bars... Biker Smile
grover
Yes the wrap looks good! I like the black side covers also
It's got the low rise bars from the CB 500 and yeah, gonna do something different with the fenders. That will be over the winter though.
Back to sprockets, has anyone considered decreasing the rear sprocket by a tooth or two to make the gearing a little bit taller - and - to lessen the difference between the 2013 and 2014 in terms of engine speed at 60 (or 70 or 80) mph?
As much as I ride dirt and gravel roads at low speeds, the thought has crossed my mind.
The reason? The perceptible buzz felt through the tank at the 4000 rpm range in 5th (about 70 mph) is mildly annoying. When I'm not poking along in 1st or second on cow paths, 70 mph is an average speed for me on decent, familiar roads.
I have thought about a drop in the rear by 1 tooth. I looked into finding 1 late last year, and no one had it advertised. Reading here that Ducati gearing works for the CB, has me rethinking the idea of looking into it again.
You should be able to get one from a 14 for the 13. 13 rear is 40T and the 14 is 39T.
(06-29-2014, 09:19 AM)CB4ME_imp Wrote: Back to sprockets, has anyone considered decreasing the rear sprocket by a tooth or two to make the gearing a little bit taller - and - to lessen the difference between the 2013 and 2014 in terms of engine speed at 60 (or 70 or 80) mph?
I have, you would have to go 3 or 4 in the rear to notice a difference, one tooth would not be worth it. I often start in 2nd on flat ground. One of the things i like about the bike is very little engine braking in 4th and 5th coming off throttle, taller gears would make it even better. After coming of 2 sport bikes this is a welcome change. One tooth in front a think would make the ride more enjoyable, the only drawback i can see from doing that is the roll on in 5th on the highway, having to downshift.
Thinking about it though
Thanks - a future mod. I'll probably start with a 38 tooth rear and go from there.
  Chain and Sprocket Options? Yata-Garasu_imp 22 2,132 12-23-2024, 04:47 AM
  Chain or sprocket problem ? The Gecko_imp 14 1,321 07-30-2024, 10:05 AM
  Acceleration and Deceleration Jolt / Harshness Mickey Dublin_imp 12 1,297 03-18-2024, 03:53 AM
Last Post: Mickey Dublin_imp
  Knocks on acceleration/deceleration Jurlie_imp 7 786 08-07-2023, 09:33 AM
Last Post: DutchRutter
  Front sprocket bolt cant be moved misterprofessionality 55 4,710 03-13-2023, 12:18 PM
  Front drive chain sprocket wear 1970Cadillac_imp 15 1,295 11-29-2022, 07:49 AM
  17 tooth CS sprocket install, comments. Bike #12_imp 11 1,012 01-03-2022, 08:30 AM
  Another chain and sprocket question bflint 20 1,613 10-13-2020, 01:00 PM
Last Post: tod.branko_imp
  Alloy Sprocket woes Ninemeister_imp 22 1,797 09-24-2020, 09:23 AM
Last Post: Ninemeister_imp
  Broken rubber on front sprocket zirconxi_imp 7 565 05-24-2020, 11:17 AM
Last Post: zirconxi_imp
