Oil Consumption During Break-in?
#31
Oil. Oil. Oil. This man is concerned about this precious fluid and has made this short video to alert us to the root cause of oil threads.
Cheers, and copied from another oil thread
Questions: shortly after the engine is turned off will the oil level be a little below what it would be after the engine has been off for quite a while, long enough for the oil in the cooler to work it’s way down to the sump? Same question for the oil filter?
Can an engine properly lubricating cylinder bores so there is an oil wedge to prevent metal to metal contact not burn a small amount of oil?
What happens to the small amount of oil it takes to lubricate valve guides?
Beer
  What did I break? Cbcarolina_imp 4 395 12-03-2023, 10:44 PM
  High mileage and oil consumption Jurlie_imp 24 2,085 04-07-2023, 06:05 AM
  Engine break out tips and tricks ACE_IRA_imp 7 496 01-29-2019, 12:30 PM
  Engine break in test - recommended vs aggressive chync_imp 7 641 11-23-2018, 06:21 AM
  RANGE and BREAK IN Streetshark07_imp 9 792 11-15-2018, 03:02 PM
Last Post: Streetshark07_imp
  Break pads.....just in time....so eaaaaaasy!!!!!! jdvalero_imp 16 1,021 08-12-2018, 09:32 AM
  Clutch Cover Removal - How To Break Goo Seal ??? markT_imp 9 698 05-30-2018, 09:30 AM
Last Post: BayAreaRick_imp
  Oil Consumption dave 37 2,413 11-30-2016, 12:05 AM
Last Post: soggybottom_imp
  New Engine Break In zippooriginal_imp 3 331 07-12-2016, 01:47 PM
Last Post: riceburner_imp
  Break in oil? Fleetwood_imp 32 2,250 01-27-2014, 02:25 AM
