Unhealthy Engine Knock / Noise
#31
Has the problem been solved?
Svp
Je remonte ce vieux post parceque
Je commence à avoir le probleme
Sur ma moto.
Pouvez vous me dire où ce trouve le reglage dont vous avez parlè.
Merci.
Per Google:
please
I'm going back to this old post because
I'm starting to have the problem
On my motorcycle.
Can you tell me where this setting is that you mentioned.
Thank you.
In this video after two minutes the adjustment is made.
Look at right side of engine below crankshaft there is a balancer shaft.
Loosen 10mm m6 bolt that clamps the balancer shaft.
Mark the position of the shaft with a marker pen.
start engine and slowly rotate counter clockwise, listen for the "whine" ( bad noise ) STOP and rotate clockwise 20 degrees.
tighten up the 10mm m6 bolt that clamps the balancer shaft.
Finished.
https://www.youtube.com/watch?v=mEgQmyknW_4
Most people never adjust this and a lot of bikes make a little noise, it also makes a difference what oil is used, a few riders notice that after the first oil change this noise starts.
Here is what's inside, the balancer shaft is excentric and you are adjusting the space between the gearwheel teeth by rotating the shaft closer to the main gearwheel on the crankshaft;
The balancer shaft rotates in the opposite direction to the main shaft and reduces vibration, this identical system is employed on the cb1300 which has a similar engine.
Whilst riding yesterday i had a thought about this noise that sometimes appears when the oil was changed by several members;
The eccentric shaft is also hollow and has oil pressure eminating in the middle of the balancer, it rides on an oil film similar to the crank shaft, so if the viscosity changes the balancer can have a different amount of play between the gear teeth and the shaft.
And like all other moving mechanical parts it would wear in and and thus have some additional play after some miles.
Just adjusted mine yesterday and i did notice that the "tick tick" noise around 1500 rpm has almost disappeared, it started creeping in at 39.000 km and although it did not worry me it's still better not to have to listen to it.
When making the adjustment try to get it so the noise is barely there, too tight and it may wear out too soon and start loosing oil pressure.......
  Front wheel bearing noise? MagnaRider 20 1,892 03-31-2026, 08:20 AM
  Engine clicking/ticking metallic noise! WTF? Tortuga_imp 28 2,366 10-11-2024, 04:53 AM
  2014 rear wheel knocking noise dunebuggy_imp 7 976 08-05-2024, 03:33 AM
Last Post: Yata-Garasu_imp
  Front ABS Brake"Rain Stick" noise bflint 3 475 07-12-2024, 08:36 AM
Last Post: Race_ca1
  Fuel pump noise? Ben70_imp 15 1,025 07-16-2022, 12:22 AM
  Valve noise (i think) Maturecheese_imp 6 655 07-08-2022, 03:41 AM
Last Post: 1973cb750
  Brake disc rubbing noise mrded_imp 8 736 08-17-2021, 03:20 AM
Last Post: furious_blue_imp
   Ticking noise from top part of engine Kingkong_imp 40 2,894 03-18-2021, 01:22 AM
  Strange wizzing noise LoyalKhan664_imp 28 2,196 10-02-2020, 05:58 AM
  Lower engine knock airenping_imp 33 2,435 09-20-2020, 12:19 PM
